Bios Drivers
antonyua
Hello,
Where Can I find Bios Update For :
Phoenix Technologies Bios
Searched Everywhere But can find a free Download of them.:confused:
    Dell Xps M1530
    Intel Mobile Core Duo T7250 @ 2,00Ghz
    Dell Inc 0xR509
    DDR 2 Dual Chanel 2 Gb
    NVIDIA GeForce 8400M GS 128 mb
    ST9160821AS 149 gb
    24/1 mb but actual speed is lower
Hi antonyua,
Although Phoenix Technologies are one of the BIOS manufacturers, you need to obtain firmware updates from the motherboard manufacturer or the system manufacturer, which in your case is Dell. Here is the main support page for your system: Dell - Search - All Dell.com. In addition, here is a direct link to the latest BIOS (2nd item on support page): Drivers and Downloads. Follow all instructions carefully. The related links on these pages may also be useful. In addition, here is a link to the forum where your system is discussed: http://search.dell.com/results.aspx...ra=False&~srd=False&ipsys=False&advsrch=False
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Oh Thank You But i Forgot You to Mention That I am Writing from other Computer and wanna Make Some updates Here ...
    Dell Xps M1530
    Dell Inc 0xR509
    ST9160821AS 149 gb
