Big windows 7 upgrade small problem
jimmy1one
I performered the Windows 7 upgrade with the kit supplied by HP. What a bear but I finally have everything up and running including all the upgrades. My problem is I can not get te computer to go to sleep. I'm certain I have screwed up the setting:cry:
High performance Turn off HD after 15 min
Sleep After 20 min
Allow hybrid off
hibernate off
Allow wake timers Disable
Power Button and lid
Power Buttom Action Setting Sleep
Sleep button action sleep
Display turn Display Off after 15 minutes
Multimedia setting
When Sharing data Allow the computer to sleep
I'm certain I have made a boo boo because I followed the direction in the Vista forum and it worked fine in vista 64. I have added all the other tips I've found in the Windows 7 tutorials and they work fine now that I've upgraded to windows 7. So it has to me my mistake using the tutorial tip regard power management in this forum. BWT I really want to thank you guys for all the the help you provide. As bad as this upgrade was and it was BAD thanks to HP, I managed to get it done in a little over 4 hours some people are still at. It's clear I was able to get it done because of all the info you guys provide
Did you mess with any settings in your BIOS? I do not know what BIOS you have, but I know I have a setting that if changed, prevents the computer from sleeping. Suspend to RAM it is called in the AMI CMOS.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Hi Jonathan
No I did not make any changes to the bios
Sorry guys I posted this to the wrong forum, it should have been in windows 7 forum
jimmy
