BFG GeForce 8400 GS
OK, I received this as a gift for my birthday on the 22 nd of this month (geforce 8400 gs). I wanted the 8600 gt but my dad, being of 65 yrs. old let the clerk at the retail store (C.C.) talk him into something else. I don't plan on doing a lot of gaming, some and video editing and capture to burn to dvd. It has one dvi and one svga port for monitors. I plan on switching to the dvi. Is this still a good enough graphics card for my needs or should I go for the 8600 as I planned.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
I have a 8400 GS and it works fine for me I can even play Crysis.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
I imagine it should be fine for your needs, but install it and see how it is for you.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
ya you can run Crysis, and all other games with it. but Crysis and games close to it will need resolutions nearing a 17, or 19 inch screen and probably on medium to low settings.
Actually the 8400 is really close to the same as the 8600GT.. hardly any difference. what you'd do if any is instead of getting a 8600GT. get a 8800GT. as the 8800GT is at least double the performance of the 84, or the 8600GT's.
The 8800GT is just that much better. Also if your C.C is anything like the one by my house. They are WAY ovepriced. and that 8400GS was probably around $120, or more. and at Circuit city the 8600GT is around $150.
on Newegg.com the 8800GT is now down to $110.. You're best bet if it's worth the 3 days wait for you would be to return to CC if can. and online buy the 8800GT.
that might not be the way yours. is. but mine is way way overpriced. just a thought. but you should probably be ok for mild things.
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
