Best way to install SP1 ?
I have just had to reinstall Vista Home Premium as my HD failed . I have installed all the updates from Microsoft and have just had a message to say that SP1 is available to download and install. I have the option of letting automatic updates do the job or use a DVD with SP I from Microsoft. Which method would be the safest?
    Intel Pentium Dual core 2.2GHz
    RAM 4 GB
    250 GB C: drive Maxtor one touch 111 external HD 250GB
    Logitech Wireless
    Logitech Wireless
    Broadband (don't know speed!)
I would recommend using Windows Update as it will not apply updates you already have. Besides, it would be much faster as there would be less to download for the same reason. Can't say about the installation time though as SP1 is a major update and it literally rips vista's core off and puts in the spanking new n blistering fast Windows Server 2008 core. [Heard that somewhere on the net]
    Custom Built Gigabyte-Intel-ATI-Transcend-SONY combo
    Intel Core2 Duo E6300 1.86GHz
    Gigabyte G31M-ES2C [Intel G31]
    1.5 GB DDRII 667 MHz [512+1024]
    Sapphire ATI Radeon HD 4770 512 MB GDDR5
    Realtek HD Audio [ALC882 codec onboard]
    Samsung SyncMaster 2033SW+ (20" Wide)
    1600 x 900 x 60Hz @ 32bpp
    1 x 40 GB P-ATA 1 x 160 GB S-ATA [Win7 with Win XP SP3 dual boot] 1 x 1 TB S-ATA
    VIP 400 W
    Zebronics Elegance
    All fan [2 on case side and 1 behind]
    Logitech Standard Optical Tilt-Wheel Mouse
    i-ball i-key Multimedia keyboard
    256 kbps Cable
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Thanks to both of you for your help. I decided to install the stand alone version and it was successful. Thanks so much.
    RAM 4 GB
    Logitech Wireless
    Logitech Wireless
