Best Graphics Card for my laptop?
jaaacob
Alright guys, this looks like one of the best places to post this question and couldnt find much using the search.
I was wondering what you would recomend as the best graphics card within £50 - £120
My system specs:
Vista Home Premium x64 Service Pack 1
Acer Aspire 5735
Intel(R) Core(TM) 2 Duo CPU @ 2GHz
4GB RAM
CURRENT GRAPHICS:
1.28GB Adapter RAM
Hope that gives you enough to go on. I have no idea about graphics cards :rolleyes: but Ive just got into PC games and want to be able to play them all quite well.
Thank you in advance :D
Jacob
    Acer Aspire 5735
    Intel Core 2 Duo CPU T5800 @2X 2.00GHz
    4GB RAM
    Mobile Intel 4 Series Express Chipset Family
    Microsoft High Definition Audio Device
    Notebook
    1360 x 980
    Acer 150 GB HDD
    Standard
    Built In
    3D Optical USB
    Built In
    <8mb/s
Hi Jacob and welcome to Vista Forums :party:
Sorry, but you cannot upgrade the graphics capability of a laptop as the GPU is part of the motherboard. :(
What you could do is to upgrade the memory of your laptop so that you have the maximum amount installed that is supported.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Noooooooooooooooooooooooooooooooooooooooo :cry:
That. Sucks.
Well on System Requirements Lab I always fail on games becasue of my chip not being compatible, even though I have 1.2 GB video RAM, and I have 3D acceleration, HW Transform and Lighting, Vertex Shader version 4.0, Pixel shader version 4.0.
Everything here passes, its simply the compatitbilty so upgrading it wouldnt really help would it?
Im really confused :confused:
    Acer Aspire 5735
    4GB RAM
    Notebook
    1360 x 980
    Acer 150 GB HDD
    Standard
    Built In
    3D Optical USB
    Built In
    <8mb/s
what he is saying is that you can't upgrade a laptop gpu :( what you have is what your stuck with all you could do is add more ram to the laptop as a whole
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Hi Jacob,
Having looked at the specifications as regards memory support, I see that you have already installed 4GB which is the maximum supported by this model.
Generally speaking, laptops are more designed for business use. They don't tend to be suitable for playing games on, especially demanding ones.
Sorry. :(
    Gigabyte IF233
Buy a desktop for gaming
    ZT Systems 7308Ma
    AMD Phenom™ II X4 920 Quad-Core Processor
    ASUS M3A78-EM
    6GB DDR2 Memory
    Integrated ATI Radeon™ HD 3200 GPU
    Realtek® ALC1200 8 -Channel High Definition Audio CODEC
    HANNS-G 19" and SONY 17"
    1280 by 1024
    WD 750GB SATA SeaGate 200GB SATA Maxtor 80GB IDE
    ATX 12V 300W
    Blu-Ray BD/DVDRW Combo Drive SATA TSST corp CD/DVDW Combo Drive
Thanks for the quick replies guys.
looks like Im stuck then :huh:
I only just bought this laptop for college and dont have nearly enough money to buy a pc as well
I probably should have researched this a bit more but I thought that becasue you can buy laptops graphics cards then it should be alright
Thanks again
    Acer Aspire 5735
    4GB RAM
    Notebook
    1360 x 980
    Acer 150 GB HDD
    Standard
    Built In
    3D Optical USB
    Built In
    <8mb/s
You can you buy a laptop graphics card? I dont believe you can, thats why you cant upgrade them.
Get a PS3 for gaming if u cant afford a decent desktop
    ZT Systems 7308Ma
    ASUS M3A78-EM
    6GB DDR2 Memory
    1280 by 1024
    ATX 12V 300W
Well my local shop sells some but they are for custom building a laptop. :cry:
Any nVidia card with an (m) after it is a card for a laptop.
    Acer Aspire 5735
    4GB RAM
    Notebook
    1360 x 980
    Acer 150 GB HDD
    Standard
    Built In
    3D Optical USB
    Built In
    <8mb/s
Since you cant upgrade your laptop. You may want to tweak it by killing processes you wont need. You may also have to set the game to the lowest settings. I bought a laptop as a portable desktop. Course I cant help trying to run some games on it lol.
IDEA :geek:
If I bought a new motherboard with a better graphics card, could i not just install that?
And if its possible, any ideas on what sort of price? :party:
    Acer Aspire 5735
    4GB RAM
    Notebook
    1360 x 980
    Acer 150 GB HDD
    Standard
    Built In
    3D Optical USB
    Built In
    <8mb/s
Sorry, but that is not practical. :( It is possible to replace a laptop motherboard, but due to the nature of laptops only the exact same motherboard can be installed as a replacement because of casing restrictions (location of vents, memory slot covers, etc).
Laptops aren't made for gaming; rather they are intended for business use. There are laptops available which make very good gaming machines, but they are not cheap. As mentioned earlier, for gaming you are better off with a desktop because it gives you more upgrade options.
    Gigabyte IF233
I give up :)
EDIT: But thanks for your help everyone
    Acer Aspire 5735
    4GB RAM
    Notebook
    1360 x 980
    Acer 150 GB HDD
    Standard
    Built In
    3D Optical USB
    Built In
    <8mb/s
Do not get fooled by the relatively large amount of "video RAM". That is shared RAM from your memory Dimms which is a lot slower than a dedicated memory on a real video card. No way to compare the one with the other in terms of speed.
    Dell
    Q6600
    HP w2207h
