Batch file help
I want to add the following registry keys using a batch file. I don't want the batch file to import the reg file, I want the batch file to add the keys itself.
This is the content of the reg file:
Code:
[HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe]
"ScreenColors"=dword:0000000a
"FaceName"="Lucida Console"
"FontSize"=dword:000d0000
"FontFamily"=dword:00000036
"FontWeight"=dword:00000190
This is what I put in my batch file after reading the reg /? and reg add /? page in cmd.
Code:
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v ScreenColors /t REG_DWORD /d 0000000a /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FaceName /t REG_SZ /d Lucida Console /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FontSize /t REG_DWORD /d 000d0000 /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FontFamily /t REG_DWORD /d 00000036 /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FontWeight /t REG_DWORD /d 00000190 /f
But I get 4 errors and only one of them gets added successfully.
    Acer Aspire 5630
    Intel Core 2 Duo T5500 1.66GHz 65nm 667MHz FSB 2MB L2
    Acer Grapevine Intel i945GM Chipset
    2x1GB DDR2 333MHz
    Intel Integrated GMA 950 256MB
    15.4" WXGA Acer CrystalBrite LCD 16ms
    200GB 5400rpm Toshiba MK2035GSS ATA-7, 250GB 7200rpm Maxtor External USB Hard Drive
Hi frankzappa77,
Here is the corrected code:
Code:
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v ScreenColors /t REG_DWORD /d 0x0000000a /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FaceName /t REG_SZ /d "Lucida Console" /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FontSize /t REG_DWORD /d 0x000d0000 /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FontFamily /t REG_DWORD /d 0x00000036 /f
reg add HKEY_CURRENT_USER\Console\%SystemRoot%_system32_cmd.exe /v FontWeight /t REG_DWORD /d 0x00000190 /f
The code itself was basically correct, it just needed some simple amendments.
Lines 1, 3, 4, and 5: 0x added to the front of the data field to indicate that the data following was in hexadecimal (0-9, A-F) as opposed to decimal (0-9).
Line 2: "" added around the data. When the item in question includes a space, enclose the term in quotes. The term here is Lucinda Console, so it should read "Lucinda Console". If in doubt, use quotes anyway.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Thanks a lot for that. So if I wanted to make the value a decimal value, I would just leave out the '0x'?
    Acer Aspire 5630
    2x1GB DDR2 333MHz
Hi frankzappa77,
Yes, you could do that. However, to avoid possible mistakes, convert the decimal number into hexadecimal format (use the scientific mode of the Calculator) and then use the syntax given above. For example, decimal 192 converts to hexadecimal C0, so the correct data would be 0x000000C0.
    Gigabyte IF233
