Back up problem Vista
draziccool
[INFO ] 0xda0 - ***** CVssAsrAPI::OnIdentify *****
[FUNCT] 0xda0 - ENTER - AsrGetSystemVolumeDevPath
[FUNCT] 0xda0 - EXIT - AsrGetSystemVolumeDevPath [0x0]
[FUNCT] 0xda0 - ENTER - BootGetWinREDevPath
[FUNCT] 0xda0 - ENTER - _GetElementData
[ERROR] 0xda0 - bootlib.cpp#515 [0x490]
[FUNCT] 0xda0 - EXIT - _GetElementData [0x490]
[FUNCT] 0xda0 - EXIT - BootGetWinREDevPath [0x0]
[INFO ] 0xda0 - AddComponent - Path: Volumes
[INFO ] 0xda0 - Name: Volume{95fa163e-bc29-11db-a456-806e6f6e6963}
[INFO ] 0xda0 - bRestoreMetadata: 0
[INFO ] 0xda0 - bNotifyOnBackupComplete: 0
[INFO ] 0xda0 - bSelectable: 0
[INFO ] 0xda0 - bSelectableForRestore: 0
[INFO ] 0xda0 - Name: Volume{95fa163f-bc29-11db-a456-806e6f6e6963}
[INFO ] 0xda0 - bSelectable: 1
[INFO ] 0xda0 - bSelectableForRestore: 1
[INFO ] 0xda0 - System Volume is NOT hidden
[FUNCT] 0xda0 - ENTER - GetVolumeNameFromDeviceName
[FUNCT] 0xda0 - EXIT - GetVolumeNameFromDeviceName [0x0]
[INFO ] 0xda0 - AddComponent - Path: BCD
[INFO ] 0xda0 - Name: BCD
[INFO ] 0xda0 - AddFilesToFileGroup - wszLogicalPath=BCD
[INFO ] 0xda0 - wszGroupName=BCD
[INFO ] 0xda0 - wszPath=\\?\Volume{95fa163e-bc29-11db-a456-806e6f6e6963}\Boot
[INFO ] 0xda0 - wszFilespec=*.*
[INFO ] 0xda0 - bRecursive=1
[INFO ] 0xda0 - wszAlternateLocation=(null)
[INFO ] 0xda0 - dwBackupTypeMask=0xf0f
[FUNCT] 0xda0 - ENTER - DiskListInitialize
[FUNCT] 0xda0 - EXIT - DiskListInitialize [0x0]
[FUNCT] 0xda0 - ENTER - DiskListPopulateLayoutInfo
[INFO ] 0xda0 - Getting disk info: \\?\usbstor#disk&ven_generic&prod_flash_hs-sm&rev_4.55#000022272228&2#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
[FUNCT] 0xda0 - ENTER - DiskForceDriversSync
[FUNCT] 0xda0 - EXIT - DiskForceDriversSync [0x0]
[FUNCT] 0xda0 - ENTER - DiskTypeByHandle
[FUNCT] 0xda0 - EXIT - DiskTypeByHandle [0x0]
[FUNCT] 0xda0 - ENTER - AsrpGetDiskLayout
[FUNCT] 0xda0 - EXIT - AsrpGetDiskLayout [0x0]
[INFO ] 0xda0 - Disk device number=3
[INFO ] 0xda0 - Getting disk info: \\?\usbstor#disk&ven_generic&prod_flash_hs-ms#sd&rev_4.55#000022272228&1#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
[INFO ] 0xda0 - Disk device number=2
[INFO ] 0xda0 - Getting disk info: \\?\usbstor#disk&ven_generic&prod_flash_hs-cf&rev_4.55#000022272228&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
[INFO ] 0xda0 - Disk device number=1
[INFO ] 0xda0 - Getting disk info: \\?\ide#diskwdc_wd2500js-22ncb1_____________________10.02e02#5&374d5d89&0&0.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
[FUNCT] 0xda0 - ENTER - DiskBuildDevicePartitionPath
[FUNCT] 0xda0 - EXIT - DiskBuildDevicePartitionPath [0x0]
[FUNCT] 0xda0 - ENTER - AsrpGetMorePartitionInfo
[FUNCT] 0xda0 - ENTER - MtMgrGetMountPoints
[FUNCT] 0xda0 - ENTER - MtMgrOpen
[FUNCT] 0xda0 - EXIT - MtMgrOpen [0x0]
[FUNCT] 0xda0 - EXIT - MtMgrGetMountPoints [0x0]
[FUNCT] 0xda0 - EXIT - AsrpGetMorePartitionInfo [0x0]
[FUNCT] 0xda0 - ENTER - MtMgrGetSymbolicNames
[FUNCT] 0xda0 - EXIT - MtMgrGetSymbolicNames [0x0]
[INFO ] 0xda0 - Disk device number=0
[FUNCT] 0xda0 - EXIT - DiskListPopulateLayoutInfo [0x0]
[INFO ] 0xda0 - Removing disk #3 - The disk is either inaccessible or is a removable disk
[INFO ] 0xda0 - Removing disk #2 - The disk is either inaccessible or is a removable disk
[INFO ] 0xda0 - Removing disk #1 - The disk is either inaccessible or is a removable disk
[INFO ] 0xda0 - AddComponent - Path: Disks
[INFO ] 0xda0 - Name: harddisk0
[INFO ] 0xda0 - Exiting CVssAsrAPI::OnIdentify()
An explaination of what you were doing and what happened, would of been the better way to go!
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
