paulatharris
Just thought I would post this to help anyone else who is having trouble with wireless connection drop outs and programmes freezing with only a hard reboot fixing the problem.
I got a new Vista laptop a week ago, I did what I normally do, that is got rid of McAfee and installed AVG8, Zonealarm and Spybot.
After a while I started noticing the wireless indicator would drop internet connection and keep local connection to other computers.
Programmes would freeze particualrly Firefox and Internet Explorer and Ctr Alt Del would not close them.
The Acer Help desk could only suggest restoring to factory settings. This I did, but this time I used McAfee and started to install programmes one by one.
First I loaded Spy bot, this worked fine. No problems at all so after a day or so, I then put on Avast. I prefer AVG but thought I would try Avast.
Again everything working well.
I then read that Zone Alarm caused many problems with Vista and that if you use a Wireless Router with Security, then Vista Firewall is sufficient for a Firewall.
So I closed firewall in McAfee and Open Up Windows Vista Firewall.
Again all OK and working well.
After using Avast for a while I thought I would try AVG again, as I prefer it for some reason.
So uninstalled Avast and put on AVG. Almost straight away the wireless connection started dropping out. Not a big problem because as soon as I checked email or opened a webpage it would restore itself, but it was a bit annoying keep seeing the little icon show that local access only.
So I had to assume that AVG was causing this. So uninstalled AVG and started McAfee again to control Antivirus and since then no problems at all.
So for me to conclude the problems initally I think were zone alarm freezing the programmes and AVG dropping the internet connection.
Currently using Windows Vista Firewall, Spybot, Avast, Windows Defender, internet explorer and system is working perfectly.
Would like to try Firefox again but will wait a few days to see if the system keeps working OK.
Hope this might help anyone else out there who may have the same sort of problems.
