Automatic Extension to Monitor
Hey,
I have recently got a Samsung SyncMaster P2270HD primarily for watch TV. Every now and again though, I want to use it as a additional (not primary) monitor. I do this via the D-Sub input on the screen (I always thought that was called VGA but anyway,) to get my laptop to extend onto this monitor I have to reboot my PC. Is there anyway for the PC to detect the additional monitor without a reboot
Thanks
Macca
    Advent 9515
    AMD Turion 64X2 2.0GHz
    2GB
    ATI Radeon X1250
    Should be 10Mbps, often less
Hi maccaquaker,
See if the following article helps - especially the items near the bottom about how to manually open the Display Settings or the keyboard shortcut keys (there are several to try). Multiple monitors: frequently asked questions.
I hope this helps.
Good luck!
    1920 x 1200 pixels
