Audio driver problem .
deaps
Hello, im pretty new here.. and i need some help with my audio driver.
(I'm sorry for my bad english)
Okay so my OS is vista 32b,
I format my PC and then i put in the disk with the audio driver which i recieved when i bought my computer, and it failed.
It says ..your audio driver files do not support your computer hardware...
i tried to download some latest drivers from the internet but they whole did the same error :X.
I'll be glad if u can help me get an audio driver. :)
Here some information
Motherboard ID 64-1216-000001-00101111-081407-Intel-BW$A0483035_BIOS DATE: 08/14/07 20:46:02 VER: 08.00.12
Field Value
Motherboard Properties
Motherboard Name Asus P5B Deluxe
Front Side Bus Properties
Bus Type Intel AGTL+
Bus Width 64-bit
Real Clock 333 MHz (QDR)
Effective Clock 1333 MHz
Bandwidth 10665 MB/s
Memory Bus Properties
Bus Type Dual DDR2 SDRAM
Bus Width 128-bit
DRAM:FSB Ratio 1:1
Real Clock 333 MHz (DDR)
Effective Clock 667 MHz
Bandwidth [ TRIAL VERSION ] MB/s
Chipset Bus Properties
Bus Type Intel Direct Media Interface
Motherboard Physical Info
CPU Sockets/Slots 1 LGA775
Expansion Slots [ TRIAL VERSION ]
RAM Slots 4 DDR2 DIMM
Integrated Devices Audio, Dual Gigabit LAN, IEEE-1394
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset P965
Extra Features [ TRIAL VERSION ]
Motherboard Manufacturer
Company Name ASUSTeK Computer Inc.
Product Information http://www.asus.com/products.aspx?l1=3
BIOS Download http://support.asus.com/download/download....SLanguage=en-us
Driver Update http://driveragent.com?ref=59
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
oh and i dont really know if its importent but when i bought my computer i had ..sound¬max.. audio driver .
deaps welcome to the forums.
You didn't say where you downloaded the drivers from but it sounds like you didn't go directly to Asus. Go here,
click on Downloads, select your OS (Vista 32 bit in your case), then select the drivers you need.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Did you install the chipset driver first?
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
