Audio choose
panais
Power User
which is better to use?
The GA-X38-DS4 onboard sound card?
Or the Sound Blaster X-Fi XtremeGamer Fatal1ty Pro?
Thanks
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
Well...it's probably going to depend.
Typically, though, the Fatal1ty will be better. It will lift sound processing from your CPU, which could actually give you a frame-rate boost in games. It's also going to give you a little bit of sound memory to play with, which will reduce load on your RAM.
If you've got the money to throw at a Fatal1ty Pro, I assume you're doing something pretty special with it. In that case, you probably already see a failing with your onboard sound. The Fatal1ty is definitely going to help you out; they couldn't charge that much for a soundcard if it wasn't a boost.
Its waste of money,its scrap,its #$$%^&&**
I bought it before 1 month,i tried every trick,adjustment
and driver in every os,nothing!!
The windows start navigation doesnt work,the sound in many games was terrible,a strange sound avery time i start my pc etc etc.
I contact many times with creative end the answer:we dont have in mind to create a new driver for now.
So... i gave 170 euro and i use the onboard sound card of my ga-p35-ds4 and IS BETTER!!
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Audiotrak makes decent cards. Used to have them at compusa before they closed up the stores.
the Pro cards from creative..the emu line are also excellent audio cards. If youre going to spend close to 200 for an audio card..dont go to microcenter..shop at guitarcenter or sweet water..youll thank me..its wierd to use a pro audio crad, but the sound quality and stable drivers are there.
I disagree with dr.funk...
I just rebuild my pc.
Now i have mobo GA-X38-DS4 compine with logitech speakers (stereo and woofer)
The sound is perfect with the new driver and software you can adjust everything.
Music,movies and games have proper sound now.
So my huble opinion is...the newest mobos have everything onboard,no need to by external sound card.
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Re: Audio choice
I agree with Dr.Funk. A semi-pro or pro soundcard will resolve a lot of issues as long as it has the Vista driver compatibility. The sound quality will be good, noise will be low, and you'll take off some CPU load. Also, if you decide to get into home recording, you might not have to upgrade again.
I recommend the M-Audio Audiophile 2496, with ASIO settings and the Vista driver (from the M-Audio website).
I also agree with Dr. Funk! QUALITY soundcards are always better than onboard.
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
