Atrac3 codec attribyt to showing under wav in GoldWave
MrElectrifyer
Electrical Engineer
I am using a 64-Bit version of vista, I tried using the software known as GoldWave and the Atrac3 codec to make a wav file and then change the extension to .at3 in order to use it in a PSP system. But unfortunately, when I try save the open mp3 file in the .wav format, I don't see the Atrac3 attributes, I installed the atrac3 driver restarted my computer then installed GoldWave, it still didn't work, I then tried it the other way around and it still didn't show. I searched for the atrac3 file that was install on my computer and it was located in C:/windows/sysWOW64 in the format .acm Is that where it is surposed to be and the format it is surposed to be in? I have tried putting it the system32 folder and changing the format to .dll, but that didn't make any difference, PLEASE HOW CAN I MAKE GOLDWAVE NOTICE THE ATRAC3 Codec attribute? Or is there any AT3 converter out there that I can buy?
    HP Pavilion dv3510nr Entertainment Notebook PC
    Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
    Inventec 1505
    4.00GB
    NVIDIA GeForce 9300M GS
    Generic PnP Monitor
    WDC WD3200BEVT-00ZCT0
    Alps Pointing-device
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with
