You should upgrade or use an
alternative browser .
ATI/Vista driver problems
I just moved my computer across my room to make it more accessible. I unplugged everything, plugged it back in and i cant play any games at the moment because of some problem with my video card drivers. I play World of Warcraft and when i click play. A message comes up that says "Failed to find a suitable display device. Exiting Program". I tried to uninstall and reinstall my ati drivers but it still wont work. Any help/suggestions?
i7 core processor
3GB DDR3 RAM
2 ATI Radeon 4850 series (crossfire)
Im not 100% sure if these are the right specs.
Im gonna try rewiping my computer..Again.
i7 core processor
3GB DDR3 RAM
Re insert the card again.
That should solve your problem.
HTPC/Desktop PC/Gateway LT2104u
Intel Pentium 4 2.8Ghz with HT/3.0Ghz with HT/Atom N450
GIGABYTE GA-81915ME-C/Intel D865GBF/Acer LT21
2x1GB DDR 400Mhz/512x2GB DDR 400Mhz/1GB DDR2-800Mhz
ECS 9800GT 512 DDR3/ Sapphire HD3650 AGP 8x 512MB/Intel 3150
Turtle Beach RIVERIA 5.1 SPDIF Out/SoundMAX AD1985/Realtek H
SONY BRAVIA KLV-32V300A V-Series/ KLV-19T400A/ Built-in
1920x1080/1980x1080/1024x600
MAXTOR 40GB
WD ESSENTIAL EDITION 1TB USB
Hitachi HDT721010SLA360 1TB SATA 150/ 250GB Toshiba
OCZ Fatal1ty 550W/
Lian-Li v351, Lancool K-62 DragonLord
Logitech Combo
Logitech Combo
512 Kbps
Just open the computer and reinser the video card? sorry im kinda new to opening the computer and knowing what to do. Dont wanna screw anything up.
i7 core processor
3GB DDR3 RAM
I unplugged the video card and plugged it back in, nothing happened though. Same error message is coming up.
i7 core processor
3GB DDR3 RAM
I am talking about the PCIe x16 Slot.
remove it from the slot.
Give it a restart without the card.
Shutdown again by pressing the Power Button once.
Put the card back again that should get it started.
MAXTOR 40GB
OCZ Fatal1ty 550W/
Logitech Combo
Logitech Combo
512 Kbps
