You should upgrade or use an
alternative browser .
Ati Say I Can Get Sound Through Dvi?
ok i am running an ATI HD 2600xt and ATI say i can get sound through my graphics card using an HDMI adapter to a TV now i tried both HDMI ports on my tv and both DVI ports on the card but still no sound through this i think i'm missing somthing but not sure what maybe not connected something to the graphics card if anyone has any idea's please let me know.
thanks
gazz
me
intel Q6600 @3.0Ghz
gigabyte EP35C DS3R
8 GB OCZ 1066 HPC REAPER
Sapphire 4870 HD 1024mb gddr5
lg flatron 20.1
western digital 350gb
samsung spinpoint 120gb
900w
thermaltake aguila
2x 120mm 2x 10cm
I have just looked at the specs and it does say built in 5.1 sound, if I remember rightly not all leads carry audio, do yours?
Operating System
Windows 11 Workstation
Ryzen 9 5950X
Creative
Drive
1500W ThermalTake Toughpower
ThermalTake Level 10 GT
Enermax Liqtech 240
Surface Ergonomic.
Logitech Performance MX
350 Mb/s
WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
Intel HD Graphics 4400
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
Looking a bit more at this, have you changed your sound device to "ATI HD sound decoder"
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
yes the leads do carry sound or at least should will check with a my dvd player not sure about the decoder i'll browse the catalyst and check my drivers again
me
intel Q6600 @3.0Ghz
gigabyte EP35C DS3R
lg flatron 20.1
900w
thermaltake aguila
2x 120mm 2x 10cm
ok it have 3 choices on sound they all say HD sound 1 say's HDMI but none of them refer to ATI would that matter ?
me
intel Q6600 @3.0Ghz
gigabyte EP35C DS3R
lg flatron 20.1
900w
thermaltake aguila
2x 120mm 2x 10cm
Check control panel->sound and see if you have ati audio listed, if so try setting it to default.
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
Try them all as default one by one
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
thank you very much that actually worked
me
intel Q6600 @3.0Ghz
gigabyte EP35C DS3R
lg flatron 20.1
900w
thermaltake aguila
2x 120mm 2x 10cm
For future reference, which option was it?
Operating System
Ryzen 9 5950X
Creative
Drive
Enermax Liqtech 240
Surface Ergonomic.
350 Mb/s
WinTV NovaTD
APC 750i Smart UPS
Operating System
windows 10
Surface Pro 3
12" Multi Touch
2160 x 144
128GB
yes
350 Mb/s
it was the HDMI option didn't even know it was their untill now
me
intel Q6600 @3.0Ghz
gigabyte EP35C DS3R
lg flatron 20.1
900w
thermaltake aguila
2x 120mm 2x 10cm
having a nightmare with vista only had it for 2 weeks and hardly any apps or games run well on it
me
intel Q6600 @3.0Ghz
gigabyte EP35C DS3R
lg flatron 20.1
900w
thermaltake aguila
2x 120mm 2x 10cm
