Ati Radeon 3870x2 problem
panais
Power User
Something is wrong with my graphic card and i cannot find what is it.
When i try to play a game i get a blue screen of death.
I upload the minidump files with the hope someone will find the solution.
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
um maybe just a bad card that needs replacing? ........... how long have you had it?
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Code:
FOLLOWUP_IP:
atikmdag+12070
fffffa60`0261d070 ??              ???
SYMBOL_NAME:  atikmdag+12070
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME:  atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a0e3895
FAILURE_BUCKET_ID:  X64_0x116_IMAGE_atikmdag.sys
Both of them are the same (this is a good thing :) ) and pojnts to your drivers , however the faulting ID is graphics driver TDR fault TDR stands for time detection and recovery and is the point where vista should detect a fault then reset your drivers , giving you the notorious display driver stopped responding and recovered note
This seems to be failing though and resulting in a bluescreen
try uninstalling then reinstalling your drivers for your gpu see if it helps , i will get more info from the crash dumps and see what else pops up
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
what catalyst are you using? try the newest one it solved the atikmdag problems for me. it doesn't show up in event viewer at all now for me.
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM, WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
Code:
FOLLOWUP_IP:
atikmdag+12070
I will wait for news.
Thanks
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
you have a few outdated drivers some going back to 08 , one to points to your 1394 bus (firewire) and usmd.sys so im thinking you should update your motherboard drivers/chipset drivers.
one also points to eamon.sys being very outdated , have you used are are you using Eset antivirus / Nod 32?
alot also point to Vista but im assuming your OS is all up to date so this must be normal
the thing is it essential to keep up to date with all drivers , i used to be of the opinion if it works then dont try to fix it , but this isnt always the case with drivers. especially if your chipset drivers are outdated. They could however just look outdated as they could be using the same drivers for certain components they have been using for years , whereas others in the package may be new
The problem with your bluescreen is its not being caused by your gpu driver failing although it is failing ,i think its being caused by the resulting process Vista brings into play to reset your driver (in my humble opinion , hopefully someone else will jump in with some ideas from the .dmp) as its unable to reset the driver in the alloted time it bluscreens
Code:
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8007c4a010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffffa600261d070, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc0000001, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000003, Optional internal context dependent data.
So all is pointing to your GPU driver failing , but the .dmp files are not telling us why , so update everything and see what happens and if you can remember exactly whats happening at the time of your bluscreen
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
i asked him what driver he was using, i have the same video card and seen the error message all the time in event viewer. it was not fixed till the latest catalyst from 9.2 onwards. he needs to uninstall everything and use a driver cleaner then install the newest catalyst. i fixed mine by doing a clean install and installing the newest chipset drivers then the new catalyst. from what you are saying he has some broken parts of the driver that need cleaned up. typical way for me to clean up is to format and install windows fresh which i believe should be done at least once a year to stop things like this. just my .02 though :)
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
Hi hclarkjr,which driver cleaner you use?
Thanks
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Guru3D - Driver Sweeper
use that one , in SAFE MODE
uninstall drivers ,m reboot into safemode run driver sweeper , reboot then install new drivers
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
that will work for you, i use your uninstaller for uninstalling stuff including drivers
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
please keep us posted as to if it works for you or not
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
Well iv tried everything.
Remove drivers,safe mode/driver cleaner,change slot on my mobo,
update bios,full format,tested in second pc etc.
The graphic card is dead,no warranty...
So i bought a new card,the GIGABYTE RADEON HD4870 GV-R487-512H-B 512MB PCI-E RETAIL
And with my new card i bought the CORSAIR DOMINATOR DDR2 4GB (2X2GB) PC2-8500 (1066MHZ) CL5 DUALCHANNEL KIT
In the end of the month i will buy and the 10000rpm WESTERN DIGITAL WD3000BLFS VELOCIRAPTOR 300GB SATA2 end thats it.
Btw did i have to change anything in my ga-x38-ds4 bios cause i insert the new ram?
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
you shouldn't have to because of a ram change.... it should just be detected :D
    1680 X 1050
    6 Mbs Down 1 Mbs Up
sorry to hear that your 3870x2 died, i love mine and have had it for little over a year which for me is a record :)
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
