As others before me...Vista lag problems
EpiCNOVA
I got this nice new computer for christmas to replace our old crappy laptop
but when i game, periodically it will freeze the game for no particular reason
this happens on all the online games i play
such as: counter-strike(and source), Starcraft, warrock, soldier front, and others
i know for a fact that it is not my internet is not the problem
it is very good comcast high speed and i used the same modem on the laptop, where it worked smoothly
plus it is not a memory problem. for not only does it have 4 GB of memory, it still lags even when i close all programs, including windows live and AVG in the bottom bar.
i can really only assume it is a problem with vista
its sad though, i knew xp like the back of my hand but with vista im near clueless XD
    Dell XPS XPS_420
    Intel(R) Core(TM)2 Quad CPU
    Q6600 @ 2.40GHz 2.39GHz
    4.00 GB
    ATI Radeon HD 3450
    Generic PnP Monitor
    C::
    Comcast high speed
Hi I don't have this problem, but when I use the internet explore it freezes for a few sec every time it needs to send somthing.
I must be some kind of Vista problem...
    mm-vision.dk (XForce)
    Intel Core i7 965 3.20GHz
    Gigabyte EX58-UD4P
    12Gb Kingston 1333MHz DDR3 CL9 DIMM (6 x 2Gb)
    GForce GTX 295
    Viewsonic VX2260wm
    1,920 x 1,080
    1 x WD VelociRaptor WD1500HLFS 150 GB 10000rpm 2 x Seagate Barracuda 7200.11 1.5 TB 7200rpm
    Corsair TX750W
    SilverStone KL01B-W
    Stock
    Logitech G5
    Roccat VALO
    12Mbit / 1Mbit
Doubtful. I run vista just fine on multiple computers,
never have any problems at all besides a sidebar bug where my icons move around.
Both of you should post your system specs.
    AMD 6000+ X2 Dual Core
    Asus Mvp Crossfire
    4.5Gbs, Kingston, and G.skill
    Ati 2600xt Gddr4 512Mb, Crossfire
    HT Omega Claro
    160Gb, 500Gb Western Digital
    580 Watt Logisys
    Apevia
    I forget
    Microsoft Habu
    Microsoft
    16mb
    Note: This is the stats of my main computer.
No games really use more than 2 gbs of ram. The extra ram is still useful for loading other apps, and running anti-virus ect though.
Doubtful, post system specs please.
    Asus Mvp Crossfire
    HT Omega Claro
    580 Watt Logisys
    Apevia
    I forget
    Microsoft Habu
    Microsoft
    16mb
Well I have observed many bugs on vista x64 that is not present on vista 32 bit. As for my system spec's, press the link at the bottom of my post´s...
    Gigabyte EX58-UD4P
    GForce GTX 295
    Viewsonic VX2260wm
    1,920 x 1,080
    Corsair TX750W
    SilverStone KL01B-W
    Stock
    Logitech G5
    Roccat VALO
    12Mbit / 1Mbit
All I can say is, make sure your drivers for audio, video and Monitor are up to date, more so EpicNova, that Generic PnP Monitor indicates you are using the std vista driver. Many issues are to be had with non specific drivers, more so in Vista x64 and it has a lot to do with Gaming.
Aside from that, all I can think is that your GPU or CPU are getting hot, have you check the temps you are getting while doing some heavy gaming or inmediately after the problems arise? What brand of PSU do you have?
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
well i mean this thing is BIG, and it stays cool, only getting warm in the back(warm not very hot at all)
and it always does it, whether the comp just started up, or if its been on for a long time
and ill check for updates on the drivers
::EDIT::
all up to date
and i dont get how to find the PSU, unless its just intel or dell
and also to any1 else who cares, specs are in my profile, or at least it should be
    Dell XPS XPS_420
    4.00 GB
    ATI Radeon HD 3450
    Generic PnP Monitor
    C::
    Comcast high speed
The driver for your monitor can not be up to date... I base this on the system specs you showed in your last thread.
It shouldn't say Generic PnP Monitor, instead, it should read the name brand of your LCD... ie: Acer AL2216AWD Monitor.
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
DellSP2208WPF(Digital)
ok i tried a different method of updating the driver and thats what i got
now in the display settings it says DellSP2208WPF(Digital) on ATI Radeon HD 3450
but, it still dosent help...
    Dell XPS XPS_420
    4.00 GB
    ATI Radeon HD 3450
    Generic PnP Monitor
    C::
    Comcast high speed
I'm not an expert by any means but AVG is a very intrusive and cpu intensive program,AVG 8 that is.It is so bad that I finally uninstalled it,there is a fix but I found it to be just too much trouble.Closing AVG does not solve the problem as a large part of it is running still in the background.
I can attest to this. AVG caused me lag in games back in v7. Shutting it down never solved the problem, uninstalling it did.
ill be sure to try this once i get home, but if it the problem, whats a good free antivirus i can use?
    Dell XPS XPS_420
    4.00 GB
    ATI Radeon HD 3450
    Generic PnP Monitor
    C::
    Comcast high speed
are you wireless? are you just simply lagging out? Does it happen every 60 seconds? If it does i can help...........but it'll cost ya ;) ;) seriously though Vista Anti-Lag Software Informer: Latest version download, news and info about this Codecase.de program.
its Vista scanning for new networks , it lags you out if your wireless , run VAL and all will be fine , you could turn the service off in XP and stop it happening but if you turn it off in Vista it brings your network down with it , the sevice in Vista is called WLAN Autoconfig
Sorry if your problem lies elsewhere :P
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Well it was in fact the problem all along, although im suprised because this never happened on my old xp laptop and im a little suprised that AVG could cause such horrible lag, but thats all behind me now i suppose
and THANK YOU to all who helped me
    Dell XPS XPS_420
    4.00 GB
    ATI Radeon HD 3450
    Generic PnP Monitor
    C::
    Comcast high speed
