Apps for your USB flash drive!
Ojaser6
You've heard of taking portable apps on your USB flash drive, right? Old school, right? But have you ever heard of taking your data AND your apps? And putting them together in a big, easy to use package?
That's what I'm gonna show you to do.
1. Click here, and download the PortableApps.com platform only. However, if you feel that the apps included in the suite are all great, you can save yourself some time and download the suite, then add more apps (if you want to).​
2. Run the PortableApps.com setup, and install the platform or suite to a folder on your USB flash drive.
2. Go back to www.portableapps.com, and download the portable apps you want. I would recommend:
  • Firefox Portable (for Internet browsing)
  • Thunderbird Portable (for email)
  • Sunbird Portable (for calendars and schedules)
  • Pidgin Portable (for IM)
  • OpenOffice.org Portable (for editing your documents)
  • VLC Player (for DVDs, videos, and music)
  • Mines-Perfect Portable (for entertainment)
3. Install the apps. DO NOT directly run the setups. Click the PortableApps.com icon in your system tray, click "Options", and then click "Install a New App", then open the app's setup .exe from there.
4. Once you have installed all your apps, you can start copying your files. First, go to your Documents folder, press ctrl-A, then press ctrl-C. Then, go to where you installed PortableApps.com, and then go to the Documents folder there. Once you are there, press ctrl-V, and your files are copied.
You now have a portable workspace!
Now... You might be thinking: "Why can't I just bring my laptop wherever I go? It will give the me the same results, anyway."
Why? Because if you know that there is a computer at your destination, you don't need to carry the extra load of a laptop. Instead, you can just carry your USB flash drive in your pocket. That saves a LOT of work.
What do you think? :D
    Dell Inspiron 640m Notebook MXCO61
    Intel Core Duo T2080 @ 1.73GHz
    Dell Memory 2GB
    Mobile Intel 945GM Graphics Accelerator
    Dell High Def. Sound
    Dell 14.1" High Res. UltraSharp Notebook Display
    One Hard Drive 120GB
    Logitech V4500 Wireless Notebook Laser Mouse
    Dell Inspiron 640m Stock
    54MB/s
  • Firefox Portable
  • Thunderbird Portable (for Internet browsing)
  • Sunbird Portable (for email)
It's Firefox for browsing, Thunderbird for email and Sunbird for calendar.
I have a SanDisk Cruizer with U3-capabilities-something. It would autorun programs... I tried it out and completely got rid of it after a few minutes, it was too messy for me.
There's a portable Chrome out there for Google fans. Then again, Google fans are already on the cloud, they're too good for hardware. ;)
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
  • Firefox Portable
Whoops. :o
I didn't proof read my post... Sorry everybody... :o I will change it now...
    Dell Memory 2GB
    54MB/s
