Hi, newbie, new post.
I will try to be specific.
Vista Business using IE8, I am using a site with content editor tool which uses JAVA in part of the interface. (I have to be vague here as I don't know if this is related to the problem) The usual problem is, oh it's their software, no it's their software!
First port of call is Vista forum, then JAVA forum, then editor vendor.
So edit the page, click update, bang!
error posted below from the close IE8 or search for problem popup.
Is there a problem with the MFC42.DLL, is this the latest version, does anyone have an idea as to the cause?
Thanks in advance. P
Problem signature:
Problem Event Name: APPCRASH
Application Name: iexplore.exe
Application Version: 8.0.6001.18702
Application Timestamp: 49b3ad2e
Fault Module Name: MFC42.DLL
Fault Module Version: 6.6.8063.0
Fault Module Timestamp: 4791a6f4
Exception Code: c0000005
Exception Offset: 00029321
OS Version: 6.0.6001.2.1.0.256.6
Problem signature:
