appcrash help
hi there, my application is crashing. i have no idea whats going on. it only happened after i reformatted my laptop from a backup disk.
this is the log
Problem signature:
Problem Event Name: APPCRASH
Application Name: casino.exe
Application Version: 1.0.0.1
Application Timestamp: 4d53e4e0
Fault Module Name: blackjackln.dll
Fault Module Version: 10.2.30.6
Fault Module Timestamp: 4d6e6fdc
Exception Code: c0000005
Exception Offset: 000fd456
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 18441
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
thanks in advance
Hamsup
Hello and welcome to the forum.
I would do the following...
1. Run a full updated AV scan...
2. Download and run a full scan using malwarebytes, free version
Malwarebytes
After that I would try a system restore, this is how...
http://www.vistax64.com/tutorials/66971-system-restore.html
If it is messed up from the formatt you need to do a factory restore to set it back to factory spec's here's how...
First make a recovery disk...
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
http://www.vistax64.com/tutorials/194765-system-recovery-options.html
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
HI again, i reformatted the comp again to the factory defaults and still the same problem persists.
Im running vista 32 bit home premium (service pack 2) btw
regards
hamsup
Don't do a system restore after removing a virus as you will reinfect the computer from the restore point. Remove the virus, delete all restore points and then make a new restore point when the computer is clean..
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Hi, i reformatted back to factory defaults. would the virus still come back??
cheers
hamsup
