AOE 2 Problem
Bogie
I've recently gotten back into playing aoe 2 conquerors and everything was running fine. I recently updated my firewall and windows vista and now every time i try and run the game, windows says "Age of Empires 2 has stopped working" before it fully loads. I've tried uninstalling, reinstalling, running without my firewall, etc. Nothing seems to work. Any advice?
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
When you get the error, does it give you the option to send an error report to Microsoft? Sometimes they have a fix for you when you send a report and it maybe something simple, give it a go and see what happens, you maybe surprised :-)
MrNeeds
    16Mb Sky bb
Na, no option to send an error report. Just checks for a solution. However it does say it will notify me when a solution is available.
    16Mb Sky bb
Have you tried running the game as administrator, or, if even that does not work, a different compatibility setting? AOE 2 is a fairly old game, and is not completely compatible with Vista. I personally had the game before too, and ran into the same issue with the game crashing, as well as texture errors.
To set the game to run as administrator: Right click on the shortcut > Select properties > Click on the compatibility tab > Select run as administrator and click OK.
Alternatively, you can also set the compatibility mode in the same manner. Just click on "Run this program in compatibility mode for:" and select an older OS, such as Windows XP.
    Gateway DX4860
    Intel Core i5-2320 @ 3.00GHz
    6GB DDR3 SDRAM
    Zotac GeForce GT 240 1GB GDDR5
    Intel H67 Express
    Samsung SyncMaster 2253LW
    1680x1050 @ 60Hz
    SATA II 1.5TB Hard Drive
    450 Watts
    HP 5189
    NexxTech Wired Optical Mouse
    Telus High Speed 15mb/s
