Hi, jdc5490, and Welcome to the Vista x64 forums.
Although this is the response that the program gives, the actual problem
probably lies more with the fact that it is trying to store its settings in the same folder it is installed in - namely %ProgramFiles% or %ProgramFilesx86% (on most computers, these folders are
C:\Program Files\ and
C:\Program Files (x86)\ - the second example is only present in 64bit versions of Windows. That folder tree is heavily guarded against possible detrimental actions, such as program alteration, file alteration, file creation, etc. because the only Vista 'user group' to have write privileges to any folder in those trees is the Trusted Installer, or the Administrator group.
Even though *you* are logged into an admin account, you do not have full administrative privileges, unless you unhide the built in
Administrator account. Therefore, the program is not running with administrative privileges that it needs to perform those actions that it is going to perform.
The best thing to do in cases like this is to run the program as admin - you can set the program to always ask for administrative privileges by right clicking on the shortcut to the program and selecting
Properties, and then in the
Compatibility tab, check
Always run as administrator. Since you have UAC disabled you should not get a prompt for this, but the program will now run with elevated privileges.
That being said, I ***highly*** recommend that you run Vista with UAC enabled. Unless you are performing mission critical data analysis using a legacy program that *needs* to be able to write its settings to the Program Files directory, there is simply no use to not having UAC enabled - it will save you in the long run - one example - See
this post at Calendar of Updates - because it mentions a 'minor' detail from a news article about UAC that is extremely important - and that is how UAC can help prevent rootkit infections.
If you are new to Vista and UAC, post back for some tips on how to use it effectively, and how to make the most of your really old programs that don't seem to want to run in Vista - and furthermore, be sure to check out the
Tutorials - Vista Forums because there is a *lot* of good information there on how to work
with Vista and make Vista work
for you.
