Annoying Window opening
Camouflage
Hi there,
I've got a little Problem here. Well its actually just an annoying thing which i would like to disable.
Everytime I attache my mobile Phone (HTC Touch Pro) to the Laptop (Vista 32bit) via USB, a Window opens and displays C:\Windows\system32
Why? What causes that? Where can i stop this window from opening?
many thanks
Camou
Hello Camou, and welcome to Vista Forums.
It may be a setting in AutoPlay for that type of media device that is set to open that folder automatically. You will just need to go down the list to see if there is one set that way, then change it to something like "Ask me everytime" instead.
Sorry, but no other ideas for this. :(
Hi there,
many thanks
Camou
It may be a design flaw in your cellphone software. Have you tried downloading and installing an updated version of the HTC Touch software?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
