Annoying Restart/Shutdown Problem
hdbg62
Let's see if anyone else has this problem; don't really understand if it's a Vista or IE7 related. This happens not on a regular basis but often enough to be real annoying and mostly when I navigate in Yahoo and/or ATT Mail where I have several accounts. When switching for a while between those accounts; first IE7 refuses to cooperate even though there is a connection to the internet and then before restarting Vista I find two or three active iexplorer processes in Task Manager which Vista will not end and when I hit restart or shutdown Vista just hangs there (at desktop) for up to seven or eight minutes before any response. After that long time just "hanging", there is usually a normal restart or shutdown process depending on which button I hit but more often than not I get a dark screen with no response at all forcing me to hit the button on my machine, i.e. an improper shutdown.
    Dell Inspiron 530
    Intel Core 2 DuoE4500 2.20G
    3.00G DDR2, 667MHz
    Intel G33/G31 Express 320
    Realtec ALC888 (7.1 Channel audio)
    Dell 22" E228WFP
    Samsung HD501LJ ATA 500 G PBDS DVD+RW DH-16W1S ATA MAXTOR 320 G USB
    5.28 Mb/s Down, 0.64 Mb/s Up, ATT Dry Loop DSL
Normally when you open IE, iexplorer.exe appears (of course) in the processes, when you open a new instance as a tab or as a new window, briefly another instance should open in the processes and disappears after 1 or 2 seconds and when you close IE, no morer instances should be displayed in the task manager.
When you have as many processes as instances of IE, it is often due to a malware, so perform a virus/malware scan.
I understand what you are saying however the instances of one or several iexplorer processes running in Task Manager occurs when IE7 has already functioning properly and I'm trying to restart/shutdown Vista. I can't end those processes and Vista takes it sweet time before and after it gets to its shutdown screen. I'm running Avast, Spybot and Spyware Blaster along with Zone Alarm Firewall and can find nothing regarding malware.
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
No offense, but when someone here suggests something it is a good idea to try it - regardless of what your setup is.
here is a scenario - you've been infected with a brand new 0-day exploit that has dropped a Trojan and 2 pieces of malware, all currently not detectable. It sits in your machine, doing its thing, and then when you go to your AT&T page it captures your username and password, and then goes to work - starting to try to send itself to your friends, etc in the background so you don't even notice it.
Then, when you later try to shut your machine down, it quickly starts a couple of IE threads to make it seem like it is doing something, preventing Windows from shutting down, so *it8 / *they* can finish what they were doing.
Do an online scan and see if you can find anything - or see if IE mysteriously locks up when trying an online scan....and when was Avast last updated? Spybot? Spyware Blaster? Do you ahve the latest versions of SpywareBlaster and the latest Beta of Spybot that is more Vista comptible?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
The only thing I have not tried is an online virus scan which I will do shortly. Avast, Spybot and Spyware are updated on an almost daily basis and as stated before, I ran several scans on both Avast and Spybot by now and none of these have ever shown any potential problems. I'll report back after the online scan. Thanks for your time.
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
Already had HJT installed but never used it (wouldn't know how, anyway), here is the log; will try online avast scan later today. Again, thanks for your time.
Logfile of HijackThis v1.99.1
Scan saved at 14:28:01, on 6/21/2008
Platform: Unknown Windows (WinNT 6.00.1905 SP1)
MSIE: Internet Explorer v7.00 (7.00.6001.18000)
Running processes:
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Windows\system32\taskeng.exe
C:\Windows\System32\mobsync.exe
C:\Program Files\Alwil Software\Avast4\ashDisp.exe
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Windows\System32\igfxpers.exe
C:\Windows\System32\hkcmd.exe
C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files\Microsoft Office\Office\FINDFAST.EXE
C:\Program Files\Microsoft Office\Office\OSA.EXE
C:\Windows\system32\igfxsrvc.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Program Files\HP\Smart Web Printing\hpswp_clipbook.exe
C:\Windows\system32\SearchFilterHost.exe
C:\Program Files\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = Live Search
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = 7-Day Forecast for Latitude 33.59N and Longitude -101.89W
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Live Search
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = Live Search
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = MSN.com
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O1 - Hosts: ::1 localhost
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: HP Print Clips - {053F9267-DC04-4294-A72C-58F732D338C0} - C:\Program Files\HP\Smart Web Printing\hpswp_framework.dll
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\2.1.1119.1736\swg.dll
O2 - BHO: CBrowserHelperObject Object - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [ZoneAlarm Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe"
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [Persistence] C:\Windows\system32\igfxpers.exe
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [IgfxTray] C:\Windows\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\Windows\system32\hkcmd.exe
O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe -startup
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - Global Startup: Microsoft Find Fast.lnk = C:\Program Files\Microsoft Office\Office\FINDFAST.EXE
O4 - Global Startup: Office Startup.lnk = C:\Program Files\Microsoft Office\Office\OSA.EXE
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
O9 - Extra button: HP Clipbook - {58ECB495-38F0-49cb-A538-10282ABF65E7} - C:\Program Files\HP\Smart Web Printing\hpswp_extensions.dll
O9 - Extra button: HP Smart Select - {700259D7-1666-479a-93B1-3250410481E8} - C:\Program Files\HP\Smart Web Printing\hpswp_extensions.dll
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O10 - Unknown file in Winsock LSP: c:\windows\system32\nlaapi.dll
O10 - Unknown file in Winsock LSP: c:\windows\system32\napinsp.dll
O11 - Options group: [INTERNATIONAL] International*
O13 - Gopher Prefix:
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O16 - DPF: {FFFFFFFF-CACE-BABE-BABE-00AA0055595A} - http://www.trueswitch.com/sbc/TrueInstallSBC.exe
O20 - Winlogon Notify: igfxcui - C:\Windows\SYSTEM32\igfxdev.dll
O23 - Service: Andrea RT Filters Service (AERTFilters) - Andrea Electronics Corporation - C:\Windows\system32\AERTSrv.exe
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: Windows Media Center Service Launcher (ehstart) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: McciCMService - Motive Communications, Inc. - C:\Program Files\Common Files\Motive\McciCMService.exe
O23 - Service: @%SystemRoot%\system32\qwave.dll,-1 (QWAVE) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: SBSD Security Center Service (SBSDWSCService) - Safer Networking Ltd. - C:\Program Files\Spybot - Search & Destroy\SDWinSec.exe
O23 - Service: @%SystemRoot%\system32\seclogon.dll,-7001 (seclogon) - Unknown owner - %windir%\system32\svchost.exe (file missing)
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: TrueVector Internet Monitor (vsmon) - Check Point Software Technologies LTD - C:\Windows\System32\ZoneLabs\vsmon.exe
O23 - Service: XAudioService - Conexant Systems, Inc. - C:\Windows\system32\DRIVERS\xaudio.exe
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
OK, try disabling the TeaTimer function in Spybot and see if it makes a difference - I have had mixed results and generally have a bad opinion of tea timer, as it has caused my system to slow down every time I have ever enabled it.
Also, do you have the latest beta of Spybot, as it is claimed to work better with Vista then previous version....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Will try the Tea Timer idea; Spybot is 1.5.2 which I believe is the latest version. If this thread stays open for a while, I'll report back. Thanks.
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
It will stay open - and the *latest* Spybot S&D is actually the Beta 1.6....with improved compatibility for Vista....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Hi, when you run hijackthis, how many iexplorer.exe processes did you have?
Check that you do not have iexplorer.exe in other folders of your Vista, for example in Windows folder or system32 folder.
EDIT:
BTW, remove everything in relation with yahoo companion
I think I'll wait until 1.6 becomes "standard issue"; got plenty to deal with having a new machine, new operating system and when it comes to computers I'm not exactly the quickest button on the keyboard. BTW, did an offline and online + Spybot scan and nothing unusual showed up. Thanks.
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
EDIT:
Well, I didn't really pay any attention to that but just tried it again and there isn't any instance of iexplorer as HJT is installed on my machine; regarding Yahoo, I have nothing connected with Companion, removed the Toolbar long ago but do use Yahoo Mail and Yahoo Messenger (rarely).
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
