When I try to drag a URL from IE to a folder, instead of the folder popping up to allow me to drop the URL into it is just blinks in the tray. To be able to complete the drag and drop into the folder I have to not have the windows open full screen but smaller so both can be seen on the screen.
It appears the window is open behind. If I click on the blinking folder in the tray it appears to minimize and on the next click it is on the screen as the active window in front of the others.
I’m pretty sure this worked correctly before. Once you dragged into a folder in the tray that folder would become active, in front and allow me to drag the url or whatever into it.
Any ideas on how to fix this?
