ai suite not working after Bios Flash
mathews2010
Banned
well i jus got a standard p5k board...updated the bios from 704 to the beta 0805...some of my oc settings had to be reset and set again...not that big of a deal...but now everything works..except my Ai Suite...which im guessn my sensors and all with my bios? but speedfan and pc probe II works...so something wrong with the program...hmm i mite jus uninstall and reinstall....or BIOS?? i dont kno
well sorry for the big pic..
totally lame..i cant downgrade BIOS using asus update...and the aflash program is only 32 bit....hmm..what can i do? i dont got a floppy drive..but can i burn the bios rom to a cd and use my bios to update my bios?
I dont think the BIOS upgrade is responsible for this.
Did you try Uninstall / Reinstall ?
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
yeah same here...the only reason i mentioned that was because about 2 minutes after i flashed it and restarted it..thats when it was doing this....right before i flashed it, it was doing great
Did you reset the CMOS to the defaults *before* you flashed the bios!?!??!
    Proudly Built by Me!
    Intel Q6600
    DFI UT LP P35 T2R
    8GB OCZ Reaper DDR2 800 C44GK 4-4-4-12 2T
    Sapphire Radeon 4870x2
    AuzenTech Prelude 7.1
    1 Acer P243 24" and 1 Samsung T260 26" Monitor/HDTV
    Both are running at 19x12
    Seagate 1TB 7200.11 (Vista x64) Seagate 500GB 7200.11 (Win 7 x64)
    OCZ GameXtream 900w
    FSB at 400 (1600) Mhz, CPU Multi @ 8 for 3.2Ghz
k i jus kicked up my fsb to 333mhz...got my cpu ratio from 266 to 290....my rams now running at 580mhz and not 800...and my cpus at 2.7ghz...how do ig et my ram back up there?
the second time my Vcore was 1.29v
3.29 ghz..
60 C on Intel HSF...
the only thing that u can maybe help me with is on how to overclock the ram...or atleast keep it at 800 when i raise my fsb..
or i dont really care...if u guys dont have time...never really overclocked...i guess i did now...jus kind of wanted to know how...i'd rather keep my system safe at the stock speeds
