speedmaster
Hey guys, i'm new to vista (about 3 days into it so far)
This week I decided to take the plunge and install vista (ultimate x64). Everything in the install went fine and I proceeded after install to set up my computer to access my wireless router, which it for the life of me would not connect to. It took me about 4 hours of disabling things I had read to do in Vista if you had these kind of problems I also upgraded the firmware in my router to the latest version (and also learned that D-Link says this model of router is Vista Compatible). I also disabled all the security on my router during this time so I knew it wasn't to do with WEP keys or anything.
After about 5 hours with zero success, I decided to change the Wireless NIC to a D-Link card that I had, and sure enough I grab the 64 bit drivers and bang everything connects and works fine.
So I installed all the updates + SP1 and begin to install Age of Conan (AoC) and let it update itself (2gb worth of patches to download) so I could play. I get into the game and every 1-2 minutes now my latency jumps up to 10k ms then back down to 300ms (which is about normal for connecting from Australia to East Coast USA).
So my guess is that this is due to packet loss, but I need to do more testing to figure out whether this problem is isolated to AoC or my system in general. While I was under XP i never encountered this problem frequently, the only times that it did happen everyone else on the server got the same problem too and it only really every occured every hour or more.
I thought I had it nailed down last night when I was doing some reading through the forums and tried some things that have been suggested there which were open ports for AoC (I actually opened up all the ports for my machines IP, cause i'm lazy ) and run a little program called Vista Anti Lag.
Now this worked great in AoC the lag spikes were gone and I played solidly for 2 hrs without any dramas, however today I went back into AoC and the problem had returned.
So far I think it's something to do with the fact Vista seraches for new wireless networks every minute creating this lag spike, which can't be disabled like it can in XP (gg Microsoft)
Things I've done:
disabled Vista's TCP auto tuning
removed TCP Ack Delay in the registry for my Wireless NIC
opened up ports on the router
upgraded routers firmware
tried Vista Anti-Lag
Thing's I haven't done yet:
Tried wired conenction to router (no cable at the moment)
Tried another game (will install World of Warcraft and see if the problem persists)
Gone back to XP to see if it still occurs with same hardware (last resort)
Tried WLAN optimizer (doing this next)
Tried different NIC + router (been thinking about buying a new card + router)
System Specs:
Router D-Link DI-524
NIC: D-Link Air Plus G DWL-G510 (rev. C)
Processor: Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz, 2667 Mhz, 4 Core(s), 4 Logical Processor(s)
RAM: 3GB
Mainboard: Gigabyte P35-DS3L
GFX card: 8800 GTS 512 MB
Vista Version: Microsoft® Windows Vista™ Ultimate
Version 6.0.6001 Service Pack 1 Build 6001
Any light you guys could shed on this matter would be greatly appreciated.
*EDIT*
Have since gone back to XP, the problem was still there, though not as rampant. I ahve since overcome it by disabling Wireless Zero Configuration under XP and the problem has gone.
Another thing I have learned is taht Vista anti lag and WLAN optimizer will rarely if ever work using vista 64/32bit drivers for some reason, there's been reports of people loading XP 32/64 drivers into vista and having much success, it's just a shame that my NIC does not have 64 bit drivers for XP (only Vista).
I believe at a later a date I shall endevour to install 32 bit vista and roll back to XP 32 drivers and see if I can overcome this issue, because I was starting to warm up to vista.
Things I've done:
System Specs:
RAM: 3GB
*EDIT*
