Advice on what to do in my situation
Blsbball
So I recently decided to dual boot my vista 32 bit with windows 7 two days ago. I created a new partition, allocating 20gb for windows 7 and everything went smoothly during that process and also on the install of Windows 7 itself. When playing around in 7 I opened up some video files on my C drive containing vista. When I logged onto vista it said those files were now corrupt and to run chkdsk. I tried that but chkdsk will not complete, stopping during an insertion into some file. Both 7 and vista are running fine without any problems despite the corrupt files but I just want to delete them as they are recorded games taking up nearly 20 gigs. I have tried everything to get them off from unlocking programs to safe mode to deleting through the command prompt and nothing has succeeded. Somehow my system restore was turned off during something so I do not have a restore point but I did backup all my files on my external hard drive before installing windows seven. What should I do next to get these files off?
thanks
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
thanks for that I was able to delete the files and free up that space. Unfortunately it is now saying the empty folder is corrupt and I cannot open it. This is the recordedtv in the public directory of windows. Any ideas?
My downloads folder in user appears corrupt as well. Its almost like very folder I looked at in Windows 7 appears to be corrupt in vista.
I assume you are booted into Vista, and it is the Vista Folders that are corrupt.
Post a screen shot of what is showing under this key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
