bigmike20vt
Hi
1st post so hello
i have just been gifted a vista ultimate key and have installed it on my PC
This is an
Athlon 64 3700+ single core running @2.8ghz
2GB DDR Ram
an Asus Nforce 4 board using onboard 5.1 sound
and an xxx 256mb Geforce 7800GTX.
I am testing out my rig for using my Xbox HDDVD drive with PowerDVD ultra, as with all the xbox issues i have decided its a bit "delicate" to waste on watching movies on it.
However, whilst my pc CAN run HDDVD it is right on the edge and drops frames now and then.
Does anyone know if powerDVD has and 64bit support and if so, will it improve my performance at all, or if not is there any software for vista / vista64 which WILL improve performance?
at a guess i only need a 10% performance gain and it will be bang on the money.
many thanks
Mike.
PS i know i could buy the Vista64 upgrade disk and try it out, however its a lot of hassle and some expense for something which may ultimately do stuff all.
1st post so hello
This is an
2GB DDR Ram
many thanks
Mike.
