A little help!!
Where is the Onboard Graphics here?
I entered Integrated Prepherals menu when i pressed Del on the restart screen and i see these:
Onboard IDE Controller: Both
OnBoard PCI S-ATA Controller: IDE
USB Controller: Enabled
Legacy USB Support: Enabled
OnBoard AUDIO Function: Enabled
Onboard LAN Function: Enabled
Onboard LAN Boot ROM: Disabled
Serial Port 1 Address: 3F8/IRQ4
Onboard IR: Disabled
Parallel Port Address: 378
Parallel Port Mode: ECP
ECP Mode DMA Channel: DMA3
Parallel Port IRQ: IRQ7
Maybe it is not disabled, that is why Resuming from hibernation is slow.
What board is it?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
none of those is the graphics card, if you have a second graphics card installed then most motherboards disable the onboard graphics automatically, if there is an option for onboard graphics card then it will say "init display first" and give you an option to select onboard or PCI-E/AGP.
Dave
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
