A little help please....
declark2
I finally updated my work laptop for our small business and have run into a problem. I was using Frontpage for our website on Windows XP, and now have Vista and Publisher. Is there a way to convert the files I have to continue updating the website? I would greatly appreciate some advice!
What format are the files in? Are they .html? And do you edit your code by yourself or do you use a program to make/edit the pages?
Let us know,
Ben
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
They are in .html. I am not the most computer savy, but regarding the code, I used frontpage to create the website then clicked publish and sent it to Lunarpages.com. I would use Frontpage to set up everything as I wanted it to appear and after the initial set up would only have to click publish and enter my username and password. Hope this helps
Dee
Ok Dee, good info.
Why cant you use Frontpage with Vista?
Let us know,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
