samhain
I just installed a zip file called "take ownership" it deposits itself in the registry and allows you to take control of certain files. So, I completely removed most of the gadgets that came installed with the vista sidebar. All but one for some reason the Norton status gadget will not allow me to get rid of it. Is there a way to completely remove this gadget? Also if I completely remove the sidebar will it cause problems for my OS?
