A few BSODs
tom982
٩(͡๏̯͡๏)۶
I've been having a few BSODs recently. I went to use driver verifier and followed the tutorial over at SF. Then I rebooted my laptop and got a BSOD on startup. When Windows restarted it said Windows could not boot and I needed to run startup repair. It found a few problems and fixed them and now my computer works fine but I want to know what's causing the BSODs.
From what I can see, Rapport appears to be causing them but I'd like the opinion of someone a little more experienced than myself :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
It is Rapport that is causing the crash. Uninstall it and then continue to run DV for 24-48 hours. If you get no more crashes then you can disable it.
BSOD BUGCHECK SUMMARY
Code:
[font=lucida console]
Built by: 7601.17592.x86fre.win7sp1_gdr.110408-1631
Debug session time: Sat May 21 09:12:40.184 2011 (UTC - 4:00)
System Uptime: 0 days 0:00:13.088
*** WARNING: Unable to verify timestamp for RapportPG.sys
*** ERROR: Module load completed but symbols could not be loaded for RapportPG.sys
Probably caused by : RapportPG.sys ( RapportPG+147d )
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME:  System
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID:  0x7E_VRF_RapportPG+147d
[/font]
I need it though, its protection when I use online banking. I guess I'll just have to put up with it :(
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
