A different "cookie" problem
julirog
Help..
When I search all files I get a bunch of files like "cookie:2of7.com". I cannot open, delete or see these files. They appear to be links to various web sites. Does anyone know how to delete or manage these files?? Where are they??
thanks,
-Roger
To delete tracking cookies: Open Internet explorer. Go to Tools, Internet options and click on delete under browsing history. I've attached a pic to show you if you don't know what I'm talking about.;)
    Intel Core 2 Quad Q6600
    Nvidia nforce 680i LT sli
    4GB PC6400 800mhz (2X 2gb)
    Geforce 8800gts 640mb KO
    750GB Hitachi Deskstar 32 mb cache, 7200 rpm
thanks, but these are not normal "cookies". I can manage those pretty well - but these are different. Have checked and deleted all cookies both manually and with IE -- these other files are still there. I also do not get any "location" noted when I try properties (from the search list).
-Roger
What spyware/ adware programs have you tried running?
Sorry for the delay. I have Norton and run virus/spyware on a regular basis. These files do not seem to be a virus or spyware - but???? They show up with a full search (advanced) on "cookie". Their are entries for yahoo, google and other popular sites as well as some that are unrecognizable. If I double click on the file, it opens IE and takes me to that site. Seems like some kind of shortcut - but, again, it won't let me delete, reset attributes or see where the file is at. When I try to delete, I get error with message that "no such interface supported". Have never run into these on XP or other systems -- just seem to be in Vista.
Thanks again,
-Roger
Hi Roger,
Run Spybot Search & Destroy to see what it finds for you. You can get it for free here:
The home of Spybot-S&D!
Spybot sure has grown since I last used it. It did not catch these files, but I have made the files inactive by changing the associated program to Notepad. That way, I can change them back if somehow they are needed. Sure curious, though, why I cannot delete or find them except through advanced search.
Thanks to all for the help.
-Roger
Roger,
Cookies are stored in two places in Vista:
C:\Users\(your username)\AppData\Roaming\Microsoft\Windows\Cookies\Low
AND
These are in the hidden folder AppData, so you will need to set your system files to not be hidden. For how if needed, see: How to Hide or Show Hidden Files and Folders in Vista
You might find them and others to be able to delete there.
