This is an issue I raised with Activision about Call of Duty Black Ops and the response I got from them, I have no idea if he is right in his conclusions and whether or not what I am sure is my 64 bit version of vista home premium should produce a 32 and 64 bit dxdiag report? I've put the technical query below, (It starts at the bottom with my initial query), and attached my 32 and 64 dxdiag report. Any help would be very much appreciated because as I said I really don't know if what he is saying is true or just rubbish
Thanks!
Discussion Thread Response (Flaviano Arroyo) 11/12/2010 08:07 AM Hello,
Your system doesn't show that it is Windows Vista™ Home Premium (6.0, Build 6002) which is not a x64-bit system, but you are running Direct X 11. This could cause conflict issues like the one you are experiencing now. A x64-bit system would also not have two different DXdiags that could run.
So in short, you have conflicting programs in your system that are both trying to run the game.
Customer
(Spencer Dunn) 11/12/2010 07:50 AM I have attached my dxdiag and dxdiag 64 bit results. The game is obviously still running I can hear all the sounds and am able to fire weapons etc but other than being able to see the compass, ammo counter, and objectives the rest of the screen is completely black and it remains that way how ever long I wait or no matter what I do? and this only happen when becoming driver of the boat whilst on foot before everything is fine. Response
(Flaviano Arroyo) 11/12/2010 04:17 AM Hello,
Unfortunately once a patch has become available through Steam there is no way to remove it. You can try completely uninstalling the game and then install again. Select to play in offline mode to see if the update does not get a forced download. Unfortunately, the moment you connect online the patch will be applied again.
To start troubleshooting this incident, since you are asking a question about a PC title, it may be a good idea to attach a text version of the DirectX file that is on your PC to your question. This file reports all drivers for your sound and video card, as well as other vital information about your system that will help us in resolving your problem.
So please send us DirectX Diagnostic report. That will give us more detailed information about what could be causing the problem.
Once we have that information, we will be able to suggest possible solutions. Auto-Response 11/12/2010 03:39 AM
Customer
(Spencer Dunn) 11/12/2010 03:39 AM I have the PC version of call of duty black ops which yesterday was running fine since steam automatically applied the new patch this morning I loaded up the mission I was playing which was the PBR boat vehicle mission which the night before had worked fine now when my character enters the drivers position of the boat at the start of the mission the screen goes black and stays black, the game is still playing and the HUD is still on screen (compass, ammo count etc) but it just stays black. How can I remove the patch? My copy worked fine graphically with no errors or crashes although sometimes it would run sluggishly and I hoped the patch would fix this problem but instead the patch has only made the game worse.
Customer
Customer
- Intel Core 2 Quad Q6600 @ 2.4GHz
- ASUS P5Q-PRO
- Corsair 1066 Dominator DDR2 4Gb
- ATI Radeon HD 4870
- Motherboard Sound Card
- Samsung SyncMaster T220
- 1680 x 1050
- Hitachi 500Gb ATA
- PSU
- Corsair 800W
- Case
- Thermaltake xaser III
- Logitech G5
- Logitech Basic
