A boot problem ?
wysiwyg
Power User
Doing some partition work a few days ago, and somehow lost the boot for my main system.
D was my main system, as you can see it holds a lot of applications and information, "C" is a fresh install,
Question is can I get "D" to reboot, it doesn't show in msconfig/boot.
I know I can transfer bit by bit, but its a long winded job, I feel there must be a way to repair reboot.
Tried the system disc Repair mode, only shows system on "C".
2 hard discs, "C" and "F" on one drive "D"on the other.
    INTEL QUAD 6600
    Gigabyte EP35-DS4
    4 gb
    GeForce 8800gt
    24" ACER
    1440 X 900
    500 GB 320GB
    700WATT
    ARCTIC
    Av.MTH, Download 8.27, Upoad 0.91
What was first system installed?
It would be good to look at Disk management to see which drive has System partition against it.....
If it was D, you first system installed you need to make sure that, this particular is the first in your BIOS boot sequence.....
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
It doesn't show in the boot sequence.
    INTEL QUAD 6600
    Gigabyte EP35-DS4
    4 gb
    GeForce 8800gt
    24" ACER
    1440 X 900
    500 GB 320GB
    700WATT
    ARCTIC
Can you post jpeg screenshot of Disk Management Window please?
Do you have Vista on your first partition ( which I assume is D on your screenshot), or are they both Seven?
Thanks
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
what OS is stored in D:?
if it's Vista Ultimate 32bit as it's label declares, you could do the following:
1. Open CMD with administrator rights.
2. Type:
bcdedit /copy {current} /d "Windows Vista Ultimate 32bit"
You will get a line like :
The entry was successfully copied to {bf6ae6df-e5ba-11dd-b7e3-00218556b93a}.
Write down the {bf6ae6df-e5ba-11dd-b7e3-00218556b93a} you'll get, it's different than mine and you'll need it below.
bcdedit /set {your_stringnumber-from-above} device partition D:
bcdedit /set {your_stringnumber-from-above} osdevice partition D:
You're good. Now reboot and you will see an option for the second OS at boot time.
    Limneos
    Intel Core2Duo E4500 2.2GHz
    Asus P5LD2-X/1333
    2GB 800Mhz Kingston DDR2
    Nvidia 8500GT
