64bit High Def proggy?
Do you have a HD monitor? If not no proggy can turn your monitor into a HD monitor.
As for programs to view HD Video DVD. I would suggest googling it.
Sorry I am not much more help than that But I hate to see empty posts...
For PowerDVD you will need to downgrade to PowerDVD Ultra 7.3.3319a if you want to play the movie from hard drive the newer version disable playing files from the hard drive.
I also believe some other versions with play from the hard drive but not sure.
I have this version and it works perfectly.
