64 bit vs. 32 bit
LeoMcD
Currently using Vista 64 bit and will soon switch to Windows Seven 64 bit. Am trying to load greeting card program 32 bit which I used on XP. I have Microsoft Greetings Workshop Deluxe, Microsoft Picture It, and Microsoft Greetings. Is there any way to get them to work, or do I need to buy new 64 bit programs
    DEll Studio XPS 435 MT
    Intel Core i7-920
    8 MB Cche 2.66 GHz
    6GB DDR3 SDRAM at 1067 MHz
    ATI Radeon HD 4350 512 MB
    Integrated 7.1 Channel Audio
    Dell SP2309W
    2048 x 1152
    640 GB Serial ATA 2, 7200 rpm
    Logitech cordless
    Logitech cordless desktop wave USB
If they are native XP programs I would right click on the icon and choose Properties, Compatibility Tab, then check Run this program in compatibility mode for: and select XP SP 2. If that doesn't work you can try checking Microsoft site searching those programs. There might be a work-around in a knowledge base article.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
