64 bit to 32 bit Vista Premium
Leif
I have to change from 64 bit to 32 bit Vista Premium because of CS3 Adobe Software support. Will this cause problems when I want the new 32 bit Vista package activated and how can I de-activate my 64 bit Vista package Thanks for any help.
Use the same product key during the installation of the x86 version. Should it not be accepted, just select to give the product key later. when the installation is finished
just call the MS Activation Center in your country by phone and tell them your story.
You are most likely to get a new working key from them.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
