64-bit DVD Question
Bare Foot Kid
R.I.P. August 13th 2014
Hello!
Let me get this straight, you're saying that because I have an OEM built machine
(HP) with a valid product key from the manufacturer that I can contact MS
and get a 64-bit DVD, even though no disc of any kind came packaged with this machine?
This came pre-installed with 32-bit Home Premium, so they will send
me a 64-bit Home Premium DVD for the cost of S&H?
I didn't want to continue this in someone else's topic --> http://www.vistax64.com/general-discussion/172519-vista-x64-sp1-media-2.html#post800357
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
You can get a OEM upgrade code from Microsoft to upgrade your version of Vista. You can't go from 32-bit to 64-bit with it. You have to reinstall.
Windows Vista: Compare editions
Check out upgrade now.
    16GB DDR667
    SAS RAID
@Guru, I know I would have to do a clean install; that would be no problem.
The 'problem' is I have no disc to install with.
Thanks :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
You can upgrade from one Vista to another version directly from Microsoft.
    16GB DDR667
    SAS RAID
Ultimate comes with both 32-bit and 64-bit. The other versions don't. You need to call Microsoft to order a media kit and license.
    16GB DDR667
    SAS RAID
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Home Premium to Ultimate: You've experienced Windows Vista Home Premium and you're ready for the best of everything Windows Vista has to offer! With an upgrade to Windows Vista Ultimate, you'll have all the capabilities you enjoy in Windows Vista Home Premium—plus all the power and convenience of Windows Vista Business.
Price: $159.00*
Get Windows Vista: Windows Anytime Upgrade
    16GB DDR667
    SAS RAID
Thanks for your help, but I want 64-bit ... :o
I also want to keep this HDD the way it is.
That is why I want to get another HDD and install 64-bit Ultimate on that.
That way my significant other (read NOT computer savvy) can still have
something to play with and I will have x64 to 'play' with.
Then if/when I ever get around to building a machine I will be able to move
that HDD to the new machine. As that piece above states; I want it all!
Thanks for all your trouble!
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Then, you need a second full version of Vista to dual boot.
    16GB DDR667
    SAS RAID
Later :shock: Ted
In that situation you would be dual booting, if you later shifted the drive that held the Vista 64 to a new computer, it would probably have a different motherboard, okay there is a workround for that. But the boot for the Windows XP 64 drive would still be on the original first drive, would it not? so how would you get around around that problem?
Best and Warm Regards
Adrian Wainer
    self build desktop PC
    AMD Athlon 64 4800 dual core Toledo 2.4 gigahertz
    Asus A8N-SLI Deluxe
    4 x 1 Gigabyte sticks
    Gainward 7600GT Golden Sample factory overclocked
    Realtek onboard sound AC-97
    View Sonic G90B 19 inch CRT [ 17.7 visible ]
    1600 x 900
    Hitachi HDT725032VLA36 quantity 4
    Cooler Master Stacker
    Thematalke Big Typhoon air cooling
    Microsoft Intelli mouse optical tracking
    Mitsumi
    3.6 Mbps HSDPA
Later :shock: Ted
In that situation you would be dual booting, if you later shifted the drive that held the Vista 64 to a new computer, it would probably have a different motherboard, okay there is a workround for that. But the boot for the Windows XP 64 drive would still be on the original first drive, would it not? so how would you get around that problem?
Adrian Wainer
Hello Adrian.
I'm not referring to XP. What I meant was to have one HDD (this one) with the
original OEM 32-bit Home Premium to be left intact. No dual boot on this HDD.
Then to purchase a second (10K RPM) HDD and install 64-bit Ultimate "Retail"
onto that. Then I could use the BIOS to boot into one or the other.
Yes, I'm aware that I would have to re-activate the OS with MS if I were to
move it to another MoBo, that's why I want 64-bit Ultimate "Retail" instead of "OEM".
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
