49*C hdd too hot
bray:way
BLAH!!
Power User
is that too hot?
i've got a little temperature wire sitting on my hdd from my front panel and that is the temp that im getting is it too hot?
thnx
Braydon
    Waayer Customs
    Intel Celeron Dual core @ 2.0Ghz
    ASUS P5kpl-1600
    2X Kingston 1600 1GB DDR2
    Zotac 9800GT 512MB
    VIA onboard HD audio
    Philips 107S6 CRT
    1280 X 1024
    Seagate 250GB SATA Maxtor Basics 250GB EXT USB Drive
    Ultrix 550WATT
    Atrix 9001
    1 normal Fans 1 QUAD Colour
    Logitech V220 Wireless
    DSE multimedia/Internet Keyboard
    8.22MB/s DOWN 0.1MB/s UP Bigpond ADSL2+
    Asus EeePc 701sd, 8GB SSD, 2GB RAM, XP pro
If that is accurate then your drive is way too high for a temp. It should be down in the low 30s if not lower.
    Custom built desktops =2 Toshiba replace HP laptop
    AMD Phenom II X4 975 Deneb core 3.6ghz
    Gigabyte GA-790XTA-UD4
    Kingston Hyper X 1.5v DDR3 PC12800 1600mhz 16gb
    MSI Radeon HD 5750 1tb
    Creative X-Fi XtremeAudio PCIe
    Asus 19" HP 20" second lcd main HP 20" remote pc.
    1440x900, 1600x900 main - 1600x900 2nd desktop
    WD Black Edition 1tb Sata II -2 WD SAS "Heavy Duty" RE class 2tb - 2 External usb/eSata WD Black 1tb main -1 External usb only WD Green Power 1tb -1
    Corsair 750w 750TX main - Corsair 600w remote
    Antec 900-2 - SSD compatible eSata ports 2 - NZXT Vulcan 2nd
    Zalman CNPS9900A cpu, twin front 120s, top 200cm, rear 120
    MSI Interceptor D200
    AZIO Ilumminated keys gaming keyboard/volume control usb
    30mbps upgrade
hmmm yea once i've finished my assesment i might chuck a fan beside it then lol thnx for the info
PS gave u some REP
    Waayer Customs
    ASUS P5kpl-1600
    Zotac 9800GT 512MB
    Philips 107S6 CRT
    1280 X 1024
    Ultrix 550WATT
    Atrix 9001
You may want to look at a few other temp tools to see what those show as well. A few offer drive temps along cpu and even video card temps as well. With several drives after a full day those generally see about 30-31C tops.
    30mbps upgrade
i just turned my comp on itz been off for like 4 hours and it is already 37 yikes :| can u recomend any tools?
    Waayer Customs
    ASUS P5kpl-1600
    Zotac 9800GT 512MB
    Philips 107S6 CRT
    1280 X 1024
    Ultrix 550WATT
    Atrix 9001
by the way these are just little temperature cable type things that i have sticky taped to the bottom of the HDD they run to my front panel which has an LCD screen to display it
    Waayer Customs
    ASUS P5kpl-1600
    Zotac 9800GT 512MB
    Philips 107S6 CRT
    1280 X 1024
    Ultrix 550WATT
    Atrix 9001
I used to have one on here that displayed drive temps as well as cpu, system being board, and even the video card. It wasn't PC Wizard 2008, CoreTemp, or SpeedFan. Lately I tried out a few hard drive monitoring sharewares that wouldn't show temps on the downloads.
The one generally used here would be the System Info for Windows or SIW tool being a freeware. Or you can still download the free version of Everest Home edition from Download Everest Home Edition 2.20 - Everest Home Edition - a freeware system information, system diagnostics and benchmarking solution - Softpedia
The SIW tool is available any time at SIW | System Information for Windows by Gabriel Topala
HDD Health is one requiring a system restart as well as Smart Drive being enabled. Flash File Recovery download flash recovery software for Windows
Besides additional cooling for the case if your setup isn't providing a false reading you could consider hard drive coolers. But for drive temps seen that high either your case any air flow or the method used is a bit off.
    30mbps upgrade
