4 Problems i Have
AlexRD
I`m having a Anti-Spam Error. I don`t know how to enable it again, i already tried everything in the Options, Advanced Options, etc.
(Btw, I have AVG Internet Security 8.0)
_____________________________________________
How do i enable this bar on my desktop??
I have an strange icon on my taskbar (i think thats the name). When i leave the pointer on the Icon, no names or something comes..
When i try to install Language Packs ( Brazillian ) the setup never ends. It stays on installing Language Pack. ( for like 2 hours) .
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    Asus G2s Keyboard from Logitech
    2 MB Wireless Network
Hi AlexRD and welcome to the forums,
At the end of the address to the picture, you added an extra "http://" so the picture cannot be seen until you edit it. Anyway, that specific bar is from a program called RocketDock. There is also another similar program called ObjectDock that I find works better for me.
Do you have any visible errors or caution windows or anything? I don't recall having ever seen that icon in my taskbar before. What happens when you click the icon?
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II 500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
The triangle that AlexRD has is, is a Nvidia graphics card error you get when nvlddmkm.sys stops responding you get a black screen for a couple of seconds and then it comes back when you are playing pc games. Nvidia has some threads about the problem in there forum. If you have an Ati card ATIKMDAG is the same thing.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
If that happens, you should do a clean reinstall of AVG.
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Razer Copperhead Tempest Blue
    Logitech G15 V1
    100.0 Mbps
There seems to be hundreds of different "fixes" for the nvlddmkm.sys issue, none of them seem to work across the board. While I have my own suspicions as to what may be causing this, a full accounting of your system specs may help solve the problem.
Motherboard make and model number, bios, graphics card, driver version, PSU make and model number, RAM make, size, model number and current speed are all key components you should list aside from everything else you can think of.
Oh, and are you running SP1?
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Well, i tried it and the Anti Spam error is still there.
Well, that triangle comes when i close the game by the Task Manager. ( because there was an error )
Strange, i can see the image here... And the Object Dock i always have problems with it. I`m not going to use it =X but Thanks. And when i click the icon nothing happens..
Yes, i`m running SP1...
    Asus G2s
    17" Generic PnP
    1440x1280
... and? :rolleyes:
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
