Solved 4 pin to 3 pin fan cable
Everlong
To xor or not to xor
I have a Zalman 9700-NT cooler, which uses a 4 pin connector to connect to the motherboard, but I want it to connect to my fan controller, so I can have direct control to when I want to lower it, only problem is the extension cables that came with the fan controller can't connect to a 4 pin cpu fan connector, they're all 3 pin.
Anyone know where I could find a 4 pin to 3 pin fan cable? I've had a look around, but not having much luck.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Hi Everlong,
You might find one here. ;)
I can't seem to find an actual 4 pin male fan connector.
So would I be able to just use a 3 pin connector like this:
As I read the 4th connection isn't actually always needed?
    ASUS Xonar DX
    100Mbps
Thanks a lot :)
    ASUS Xonar DX
    100Mbps
cyberguys.com might have them.
    16GB DDR667
    SAS RAID
You're welcome Everlong.
