Solved 32bit to 64bit
  • Thread starter Thread starter stew2
  • Start date Start date
S
stew2
Hi, iv just ordered parts online for my dads pc and picked amongst other things for him these two items:
  • TW3X4G1600C9D - 4GB (2x2GB) Corsair XMS3 Dominator DDR3, 1600 Mhz
  • 512 mb Sapphire HD4650
He doesnt game so the graphics card is just purely to give him a picture on screen but this is going to give him 4.5gigs of RAM. He's only got Vista Ultimate 32bit retail while i have a Vista Ultimate 64bit OEM disk. So is it possible to send him my 64 bit disk and for him to install the 64bit version with his code so he can access all the ram hes going to have.
Hello Stew,
If you had a retail Vista installation disk, then yes without a problem. However, it depends on what type of OEM installation disk you have. If it is a OEM Vista Recovery disc, then it will not work. If it is an express installation disc, then you might be able to.
64-bit media should have been included in the box with the retail Windows Vista Ultimate though. You can also order a replacement 64-bit from here as well for just S&H.
Windows Vista Alternate Media
Hope this helps some,
Hi Brink
I have the vista ultimate 64 bit upgrade disk that i use for clean installs. Iv never installed a 32bit Vista and asking my dad about technology is tough going lol. Il give him a phone though and ask him to look in the dvd case and see if there is 2 disks.
Cheers for the help
you need to make sure that the hardware is 64-bit compatible. I didnt look at your system specs but that is a key issue. How is he going to have 4.5GB of RAM with only 2x2GB RAM chips? If you OEM disk is from like HP for example, it cant be used on another pc unless it is hacked, but that isnt a good thing to do.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
Hi Brink
Cheers for the help
You're welcome Stew.
As Blackhawk suggested though, I would verify that there are 64-bit drivers available for all of his devices, and that he has a 64-bit CPU first though.
Should work no problems Stew ;)
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Cheers guys, all his components will work together. This is what i picked for him:
  • ASUS P5Q3
  • Core2Quad q9550
His 4.5 gigs of RAM comes from having 4 gigs of RAM plus the 0.5 gigs on the graphics card. Its just an upgrade as hes keeping the case, power supply, dvd drive etc he uses. Iv already downloaded all the 64 bit drivers for him and then started to download the service packs, DirectX, .NET etc and then thought will this actually work lol.
Iv just got off the phone and he tells me his disk is actualy the vista ultimate 32 bit OEM that he bought online. So it would have to be installed using a vista ultimate 64 bit OEM upgrade disk and then using his 32 bit OEM code.
That's good news. :)
However, RAM on a graphics card is treated and used separately than system RAM. He would have 4 GB of RAM and 512 MB of graphics memory to be technical. ;)
Yeah i know that lol. It was just the 32bit limitations of accessing the RAM that i was worried about. Id basically advised him to get the above then realised that a 32 bit OS can only access around 3 gigs ish of RAM.
To my knowledge the graphics cards 512mb would be included in that 3 gigs of ram. Meaning he was missing out on using 1.5 gigs of "real" ram :p. But anyway why cant microsoft sell one version instead of 12 so that it stops stupid questions like mine.
But thanks everyone for the help and putting my mind at rest. He will install as i originally planned and hopefully everything will go OK.
LOL, no problem. :p
If you run into any problems, just let us know. :)
