32-Bit X86 VS 64-Bit X64
SeanBond
whitch version do you use and why?
what are the Benifets of 64-bit apart from more ram
and how good is program compatibility?
    Intel Pentium D920 2.80Ghz x 2
    Asus
    2Gb DDR2 667Mhz
    ATI HD 2600 Pro 512Mb DDR2 Overclocked
    8.1 High Def Intergrated
    17" Iiyama ProLite E430
    1280 x 1024
    1 x 500Gb WB SATA II 2 x 80 Gb Samsung IDE
    500W Thermaltake
    Cool Gaming Case (Dont know name and cba lokking it up)
    4 x Blue LED 12cm Fans and 2 x 8cm Blue LED Fans
    Microsoft Optical Mouse 3000
    Saitek Eclipse II
    8Mbit (i get 3 Mbit)
Hi Sean
I use Ultimate x64, I started using x64 because like most people, I wanted to know what it was like.
x64 is more stable than x86 and when I work with video it is also a bit faster, remember though that most other installed programs are x86.
Program compatability is good for me, I have only one program (from 1999!!) that will not install
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
do you know if program like adobe cs4 programs and things will work fine
i am thinking of downloading it soon but want to know if i will see a speed increase (or deacrese) and if all my programs will work ok
and will i be able to dualboot 32-bit and 64-bit at the same time?
    Asus
    2Gb DDR2 667Mhz
    1280 x 1024
    500W Thermaltake
    Saitek Eclipse II
SeanBond,
This link will help determine if a program or device is compatible with the 32 bit or 64 bit Vista.
Windows Vista Compatibility Center
With only upgrading to 64 bit Vista, you may not notice much speed increase since everything else is the same. However, you will have more potential for a performance increase with the 64 bit Vista.
Yes, you can dual boot with the 32 bit and 64 bit Vista as long as they are each installed on a separate partition or hard drive, and do not share a data drive or partition. Sharing a data drive or partition between 32 bit and 64 bit Vista will usually lead to it becoming corrupted and potentially losing what is on it.
Photoshop CS2 had issues with Program Files (x86). I had to install to Program Files. It was partially 64-bit and ran great in XP x64 SP2. I have not reloaded CS2 in Vista x64 because I am waiting to get CS4.
    16GB DDR667
    SAS RAID
thanks for the link
i will install 64 bit and post my verdict soon :p
i am also thinking about geting XP pro 64-bit to see how that is
    Asus
    2Gb DDR2 667Mhz
    1280 x 1024
    500W Thermaltake
    Saitek Eclipse II
why dont u get cs4 SCSIraidGURU
i have the adobe cs4 master collection already and it wrk great :p
    Asus
    2Gb DDR2 667Mhz
    1280 x 1024
    500W Thermaltake
    Saitek Eclipse II
thanks for the link
You're welcome SeanBond.
CS4, Microcenter did not get it in yet.
    16GB DDR667
    SAS RAID
