32 bit to 64 bit
Vanzeg
Hey, i would like to switch from 32 bit vista ultimate to 64 bit because i want to upgrade to 4GB of RAM and be able to use all of it to it's fullest.
Right now i have 2 paritions on my single HDD. 1 is my back-up windows xp partition, it is also the larger of the 2 so i put most of my data and programs on there. My second partition is my Vista Ultimate 32 bit version on which i use some programs from my windows xp partition that i wouldnt like to lose.
Is there any way i can change from my 32 bit version of windows vista to a 64 bit version without losing all of my data... including the data on my windows xp partition if possible.
Thanks.
Will you have to pay for the upgrade from 32 to 64?
Best and Warm Regards
Adrian Wainer
    self build desktop PC
    AMD Athlon 64 4800 dual core Toledo 2.4 gigahertz
    Asus A8N-SLI Deluxe
    4 x 1 Gigabyte sticks
    Gainward 7600GT Golden Sample factory overclocked
    Realtek onboard sound AC-97
    View Sonic G90B 19 inch CRT [ 17.7 visible ]
    1600 x 900
    Hitachi HDT725032VLA36 quantity 4
    Cooler Master Stacker
    Thematalke Big Typhoon air cooling
    Microsoft Intelli mouse optical tracking
    Mitsumi
    3.6 Mbps HSDPA
Hello Vanzag and welcome to Vista forums!
Probably the 'safest' way would be to get an additional HDD and put 64-bit Ultimate on that.
Just be sure you have access to all the relevant drivers before you begin.
Later ;) Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
If i get a second HDD for my 64 bit version, wil i be able to use/play the programs that i installed on my xp/32 bit version with the power of 4GB?
Just to point out that you may not be able to use all 4GB. I'm having this problem at the moment. If your chipset/motherboard is limited to 4GB RAM, then you'll only be able to use around 3 - 3.5GB (even on x64).
    Intel Core 2 Duo @ 2GHz
    4GB DDR2 @ 667Mhz
    nVidia GeForce Go 7600
    1x 160GB 7200rpm 2.5" SATA
It is - Memory
4 x 240-pin DIMM sockets
Dual Channel DDR2
Maximum of 8GB of DDR2 533/667/800/1200MHz SLI-Ready memory
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
