Solved 2nd Monitor in Portrait?
mjcace
Not sure if this is the best place for this , Mods please move it if necc.
I have searched these forums and looked other places online. I am trying to get my Samsung 2443bwx 24" into portrait mode. I have vista home premium 32 bit. Currently I have a 32" lcd as my main monitor and I have the 24" next to it. I have look thoughout the Display settings and see nothing :(. I am cpu n00b so nothing is really easy for me. Thanks for any Help.
Adapter type: Radeon x1300 Series
dell dimension c521
amd atholn 64 processor 3800+ 2.40ghz
2046 mb ram
also: if anybody knows what I will need to do to install a 3rd monitor please let me know. If I do this, it will be another samsung 24" and I will replace the 32" lcd with a samsung/dell 30". Thanks again
Hello mjcace, welcome.
I believe (I know NVidia does this) that if you open up the control panel (from your Video Card manufacturer) there should be a setting for video position. You can change from vertical to horizontal and so on. That should work I hope.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Thanks for the reply. I do not understand exactely what to do. In my control panel, my main spot for adjustment seems to be " personalization/display settings/advanced settings/ and when I go into there I see 4 tabs(adapter/monitor/troubleshoot/color management), I have look throughout all of them. I am sure I am looking in the worng spot or something but if there is any way you can be more specific then maybe I can figure this out.
Thanks again for your help.
You are. ;) Not too worry though. When you installed your video cards drivers, assuming you didn't install them through Windows Update, you should have also installed the Catalyst Control Center, which is where you neeed to go to make that setting change. Right click on an open spot on the desktop and select the CCC from the menu. If it is the first time you have used it it will ask if you want to use it in Basic or Adveanced mode, go for Adveanced. Then once you are there this is where you need to look,
then just click one the appropriate monitor, then select the rotation from the dropdown.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Stormy has it covered. Thanks.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Thank you very much. I got it! I had to update my driver and then download Catalyst Control Center. I gave you both Rep
Thanks again
Mods, feel free to lock this Thread.
Don't need to lock it, just mark it solved.
~Lordbob
P.S. Thanks for the rep.
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
