This is what I see on my C Drive with Vista Home Premium
1.48.3 GB used space on Local Disk (C When I Click Local Disk C then Properties, Blue Red Pie (51,940,466,688 bytes) 2.28.1 GB Size on Disk When I Open C & Select All, Then Click Properties (30,206,545,173 bytes) 3.That's a Difference of 20.2 GB & I Checked Show hidden files and folders & Remove the checkmark from the checkbox labeled Hide protected operating system files. 4.33.2 GB is the size of my Compressed Backup on my Acronis TrueImage11 C Drive Backup to an External HD, so I think the 48.3 GB is true. Where could the 20.2 GB be hiding?
It's system restore points that's taking all that space up.Here is a link that might explain more. basically you can erase all the restore points off except the last one if you go to disk cleanup. Step 13-
