100% CPU when plugged in.
valar
hey guys, i just got a new laptop, and whenever i have it plugged in the cpu runs at 100% even when idle. when it is on battery power the cpu runs like normal. i am getting this from the reliability and PERF. monitor on windows vista. also when it is plugged in the CPU max frequency is stuck at 50%. i have tried to change all the frequency settings on my power management but it will not go above 50% while plugged in. i already updated all of my drivers and my bios. does any know what this problem is and how to fix it.
    Dell Inc.
    Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz (2 CPUs), ~2.0GHz
    3070MB RAM
    ATI Mobility Radeon HD 3650
    Speakers / Headphones (IDT High Definition Audio CODEC)
    Generic PnP Monitor
    309 GB
update on the problem. it seems to only happen when the battery is charging when the power cord is plugged in and not charging it works fine.
    Dell Inc.
    3070MB RAM
    Generic PnP Monitor
    309 GB
This sounds like a sensor error.
What are you using to read it? The one that comes with Vista sucks. Download a good one, either Speedfan(60nm) or RealTemp (45nm)
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
