i have this prob, i hope you can help me.
every time i start or reboot my pc, it always says fails to start.
File: windows/system32/config/system
status:0XC0000E9
i also did memory diag test and it says no prob on my pc. but evrytime i open my pc it always go throu to (safe mode, command prompt, windows start normally etc.) and click windows start normally to open my pc. it really botherd me a lot.
i also try restore point and nothing happns.
i also did reinstalling my vista but same problem appears.
i cant find any solutions on the web regarding the 0XC0000e9.
and i reset the motherboard and now i start me pc and onli goes to the image of the motherbord and it doesn´t move... NEED HELP!!!!
status:0XC0000E9
