Ultimate Malware Removal Guide
Brink
Staff member
mvp
Ultimate Malware Removal Guide -- Purge Your PC of Junk Files!
Malware is everywhere. You can't browse on any Internet tech forum without someone mentioning this word (with disdain), usually in search of a remedy after being infected with spyware. No matter how careful you are, we’re guessing that many of you have had malware inadvertently installed on your system and may have even ended up reformatting your computer as a last resort. While that may have been the most thorough solution, it is in a sense admitting defeat. Or worse yet, you took your computer to get cleaned and was charged anywhere from $50-300 -- a high price for humiliation. But don't fret, because you can actually purge your system of malicious software for free! Just follow our comprehensive guide.
Read more at: Ultimate Malware Removal Guide -- Purge Your PC of Junk Files! | Maximum PC
Thanks Shawn for the info.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
You're welcome Mansrm. I thought it would be helpful for the folks here when I ran across it. :)
Who makes Malwares and viruses?
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Hello Jerin,
Sorry, never even tried or have wanted to. :geek:
Depends on user activity...
    Compaq
    15"
    160 GB WDC
Pretty cool Shawn, although they left Spybot SD out of the list. :confused:
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
The Bengali Lancers are disappointed about that too Airbot.:rolleyes:
This list Shawn, is a real 'doozie', if and when you have about 4 hours to spare. It ain't just a scrub, it's a steamclean, sandblast and epsom-salts purge, all rolled into one. Man! Your pipes would be clean after this lot.;)
Any chance of including it as a complete 'package' in your Vista Forums>Software>Free Software List for Vista? Or do copyright issues come to a head?
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Hi Aaron and Tony,
Yeah, it's a shame that they left out Spybot S&D.
Most of the programs are already listed in the Free Software List, but the others just seem not to be real helpful considering other programs can do it easier or to hard for the average person to use.
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
After reading your suggestion may i say it doesn't work. Sounds like something half hearted.
Read this
http://www.vistax64.com/system-security/209046-help-norton-kaspersky-cant-find-virus-worm.html
I understand your frustration Trax1963, and it certainly looks like you have a bitter pill to swallow.
However, in keeping with KISS methodology, I have three questions;
Q1.....Do you have automatic MS Windows Updates, and do you install them....the critical and important?
Q2.....Have you run the Windows Malicious Software Removal Tool? Jan 09 Version here; Download details: Windows Malicious Software Removal Tool
Q3.....I am aware that a Java script nasty can embed itself right in the Drive and location that you mention..... D:\Recycle Bin, and that the Windows Live OneCare Safety Scanner has successfully located it and given details at the scan finish on how to quarantine and remove it. Have you tried the Windows Live OneCare Safety Scanner, beta Version for Vista....Full Scan? Here; Windows Live OneCare safety scanner: Free online tool for PC health and safety NOTE: You'll need to download this and run it in MS Windows Internet Explorer to succeed.
Both are free to use, worth a try, and often overlooked as useful tools.
By the way, the latest Version of the Malicious Software Removal Tool, is due for release with other MS Windows Updates, on Tuesday this week.
Hope this helps.
G'day. Beautiful scenery....
Can i come and stay...
Answers:~
1 Yes. I spent all night and morning getting all the updates.
2 Yes. Installed
3 No But have installed and scan is in progress as i write this...;)
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
Safe to say it didn't work!:mad:
Bought a new drive so cheap now they cost less than repairing a computer nowadays...
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
